Old 27-11-2016, 01:16 PM   #1
Froger
Default Engine size physically 2L 2.5L
G'day all .
Just wanting to know if there is a difference in physical size from a stock 2L motor to a 2.5 turbo motor ? I'm wanting to have a motor to use for a mock up to go into my XK Falcon Pano , the stock 2Ls are really cheap so would prefer to use one of them to fit up then buy a turbo 2.5L when I have sorted it ..
Also are the block to bellhousing the same between the 2 engines..
Cheers Fred
Froger is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2016, 02:10 PM   #2
DZFord
DZFord's Avatar
Default Re: Engine size physically 2L 2.5L
Definitely a difference in size. As I'm sure you're aware, the Volvo 2.5 out of the XR5T has an extra cylinder. So i'm thinking that the block is physically bigger but don't have exact measurements for you.
If you want to start with the Mazda-Ford 2.0L Duratec, that is a good option, and then you can always upgrade to the 2.3 or 2.5L Duratec engines, either out of the Mondeo 2.3 or Mazda SP23 or SP25. This family of engines are all similar in size, and are basically stroked out versions of the 2L.
Old 27-11-2016, 04:39 PM   #3
commodorenutt
commodorenutt's Avatar
Why not look for a crashed FG Ecoboost to come up at auction?
At least then you'll get a RWD configured motor & box, which will be much easier for a conversion.
commodorenutt is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2016, 05:04 PM   #4
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Agree with above. Use an FG Ecoboost
+ XK =
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2016, 06:11 PM   #5
DJM83
Barra Turbo > V8
DJM83's Avatar
As someone that has owned both, stuff the ecoboost. Throw the 5 banger in it purely for the noise.
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2016, 08:34 PM   #6
Froger
Thanks fellas . Have more options to look into now .
Old 27-11-2016, 08:38 PM   #7
xr8cam
Be boring and put a V8 in it. Probably easier & cheaper.
xr8cam is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2016, 06:46 AM   #8
commodorenutt
XK with a V8 is very tough to get engineered these days.
I like that the OP is thinking out of the box, and wants to do something unique.
The Ecoboost are under-rated, and perform well in the heavy FG - so in a much lighter XK, it will be a real surprise packet.
Old 28-11-2016, 10:01 AM   #9
DZFord
DZFord's Avatar
Plenty of good RWD conversion options for the Duratec 2.0L as well. It is a popular conversion for the Ford Escort, and a lot of Caterham cars also use the Duratec engine in RWD format.
Old 28-11-2016, 11:10 PM   #10
BUZ440
Hi fred im selling my 2.3 l duratec, with W58 box and matching bellhousing if interested let me know, was going into mk1 cortina wagon
Look at this on eBay http://www.ebay.com.au/itm/262728419237
BUZ440 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2016, 09:09 AM   #11
DZFord
DZFord's Avatar
Another manual gearbox option for RWD setup is the manual box out of MX5, specifically the NC model. As long as you use the MX5 flywheel and clutch arrangement, it apparently bolts right up, no custom bellhouse needed.
Old 06-12-2016, 09:33 AM   #12
Froger
Cheers Buzz440 but really leaning towards a 2.5T , did you have to make an adaptor plate up to fit the box up or can you buy one ?
That's pretty handy to know DZFord that's the sort of info I'm after . I also didn't know about the Eco Boost engines ..
Thanks fellas.
Old 06-12-2016, 07:11 PM   #13
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Try Retroford in the uk, they can supply everything you need to convert zetecs and duratecs to rwd application...
Escort RS2000 Restored factory a/c and alloys.
TD Cortina Unrestored 35 000km 6cyl manual.
Mk1 GT Cortina Project.
FG XR50 Daily.
Rallye Sport is offline   Reply With Quote Multi-Quote with this Post
