Old 28-10-2024, 06:27 AM   #1
Default Blasting Garnet - What Grade?
If the main task is cleaning up chassis and subframe parts (forged, cast, pressed ferrous) with some age/weathering, what’s the suggested grade of garnet for blasting prior to new paint?
Old 28-10-2024, 07:34 AM   #2
roKWiz
Cabover nut
roKWiz's Avatar
Default Re: Blasting Garnet - What Grade?
Blasted our 6mm plate hull with 30/60 80 grade garnet, would be a suitable for a little heavier steel, like a truck chassis if that's all you were using it for.
Brown aluminium oxide is a lighter grade for surface prep.
Boatyard supplier was Blastone in Silverwater don't know if they are still around.
Most boatyards have all gone to beadblasting lately.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2024, 08:03 AM   #3
Unfortunately, Blastone (now in Wetherill Park) only do 2 tonne bags of 30/60.
Will give this grade a try with a 25kg bag from Hare & Forbes.
