Old 05-06-2005, 04:46 PM   #1
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
Default EL XR6 Hole?
Im in the process of wiring up driving lights on the EL XR6.
I cannot for the life of me find a hole in the firewall to feed a wire through for the switch.
Does anyone know where I might find one, or where I can feed a wire through the firewall?
Old 05-06-2005, 05:51 PM   #2
InitialD
Low and Loud
InitialD's Avatar
if its auto, you can use the Clutch Cable hole...
Ive ran alot of my wires thru the firewall where the main loom enters the cabin ;)
Old 05-06-2005, 06:09 PM   #3
the_scotsman
MY21.5 Mustang GT
What if it's a manual? :P
Thanks anyway lol
Old 05-06-2005, 06:35 PM   #4
mr_efxr
Not your average EF Wagon
mr_efxr's Avatar
Use the hole where majority of the wires feed through already. Its located just under your brake booster. It may be a tight squeeze but, this is the only hole I recommend to use. The wires feed through a rubber sleeve fitted on the firewall.
Power by HeadTech Performance Williamstown
The recently SOLD 95 EF Wagon 5spd NA SLEEPER
The Daily cruisers now *95 R33 Skyline GTS-T RB25DET *93 Lexus GS300 2JZ-GTE
Car enthusiasts visit Unique Cars and Parts
mr_efxr is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2005, 06:37 PM   #5
the_scotsman
MY21.5 Mustang GT
OK I'll give it a go tomorrow evening....only one wire needs to fit through.
I've just fitted the lights to the front....had to make up custom brackets as there is NOWHERE to mount the damn things...luckily there was a flat part of metal above and behind the light to fix the bracket to.
Old 06-06-2005, 07:49 PM   #6
mcflux
mcflux's Avatar
Drill a nice fat hole through the steering column plate ;)
I did that (well, I did more than just drill *one* hole) when putting a cable thru the firewall
-Dave-
Old 07-06-2005, 08:36 PM   #7
the_scotsman
MY21.5 Mustang GT
DONE!!!!
I ended up using the accelerator cable hole, was easy to access and had plenty room....
Im very pleased with the results!!
I still need to tidy up the wires a bit. And the light shines under the car at the front, almost looks like white neons or something LOL, I'll need to try and block that off a bit.
I might try hacking up the vent cover that I removed, to block up the hole on the outside of each light, make it look a bit more snug....but I'm quite pleased with the result!
Old 05-07-2005, 06:40 PM   #8
Muley-EF
I WANT SOME!
where did u get em from?
Old 05-07-2005, 06:47 PM   #9
the_scotsman
MY21.5 Mustang GT
lol...
I got htese ones from Repco, they had a good sale on recently, 20% off all driving lights.
They are Narva ones from memory, were about $150.
