Old 14-08-2005, 05:36 PM   #1
Rmyers
Does Steve have a car?
Rmyers's Avatar
Default Custom brake lines????
Hey guys, just a question regarding custom brake lines...
I was thinking before that since my car has got a complete EF loom running through it, i've now got the option to install ABS as all the wiring is there for me.
I am going to be aquiring an EF v8 brake booster and master cylinder that i wanted to chuck in, and because the fitting position for the brake lines differ between EA and EL, i was going to try running EF brake lines and have a go at installing ABS as i have an ABS module (think that's what it's called) lying around.
Here's the problem tho, the ABS module on EF/EL's mount at the front of the passenger side quarter panel and hence the steel brake lines are designed for when it's in this location. Unfortunately, I have no room under there as i have 3 inch intercooler piping and a cold air induction in this spot now.
My question is if it's possible, and if so how much would it cost to have custom brake lines made up that would let me locate it in a different position, such as in the engine bay (like on AU's). Also, are there any legal issues when doing this, ie do i need to get an engineers certificate for this kinda work, or is it ok aslong as a qualified professional tackles the job...
One last thing, can they custom make up steel lines like the standard ones, or would i need to use braided lines for something like this??
any help would be much appreciated
cheers
Steve
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 08:22 PM   #2
LTDHO
The one and only
LTDHO's Avatar
Steve
I can hook you up with lines.
Chat on MSN..
Tuned by CVE Performance
Old 14-08-2005, 08:26 PM   #3
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
Just go to a brake shop and they'll be able to make lines up for you, just need to tell them how long, and they just cut it off and put the ends on them. Keep the originals though, because they'll need to see what ends were originally on them.
You'll have to bend the lines up yourself though, which is no easy job in itself =/
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 11:28 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
is the bending of the lines similar to that of copper lines for LPG?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 14-08-2005, 11:51 PM   #5
niko
likes falcon's
niko's Avatar
wen ya finished with it tell vicroads its not an ea, that its a model than never existed!!
www.carhubsales.com.au
Old 14-08-2005, 11:52 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
the EC Falcon?
Old 15-08-2005, 09:28 AM   #7
NZ
NZ's Avatar
EE falcon would be more approproiate. Its not quite an ef but and is only going to bear little resemblance to an ea
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 15-08-2005, 12:46 PM   #8
ilsautomotive
Former E-Series Member
Sounds good Steve, I was going to use the EL booster but chickened out and went for an EB XR one.
Old 15-08-2005, 06:04 PM   #9
Psycho Chicken
Psycho Chicken's Avatar
Go to Better Brakes in Cheltenham, ask for Kerry. Cheap as and he knows his stuff. I got a clutch line made up with 10" of braided line for $38.
Old 15-08-2005, 06:45 PM   #10
GTENVY
GTENVY's Avatar
Would it be legal to have braided lines from the booster right through to ABS module then on the the calipers. I know it sounds a bit over the top but save you having to bend them etc???? Just a thought :dr_Evil:
FM Mustang GT, manual - Daily driven
Live, Love, RACE
SOLD: AU III XR8
Originally Posted by nstg8a
cars are to be driven, ornaments are to be looked at. the two should never be confused.
GTENVY is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2005, 06:56 PM   #11
Psycho Chicken
Nope, braided lines still flex.
Old 16-08-2005, 08:35 AM   #12
EA2BA
PM me if you want
EA2BA's Avatar
You cant have hose running under the car braided or not, it has to be solid metal pipe (from memory this what the ADR's say).
Old 16-08-2005, 11:30 AM   #13
EFFalcon
Last warning
EFFalcon's Avatar
thats interesting, does that only apply to brake lines?
you can get flexi LPG lines, and i know steves car has them running from tank to converter.
Old 26-10-2005, 11:15 AM   #14
OED666
OED666's Avatar
does any one know if an EL master cylinder will fit an ed.. the el its from has abs, and so do i...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2005, 11:27 AM   #15
EA2BA
PM me if you want
EA2BA's Avatar
No it wont, you need the booster and master as they slightly changed the mount holes so it cant bolt on, well EL master onto EA didnt work, also the positions of the actual brake line bolt points is slightly different so requires some bending to get into place.
Old 26-10-2005, 11:30 AM   #16
OED666
OED666's Avatar
ok, i have found the master and booster as one complete piece...
damn, if only i had my car here today...
Turbo Barra ED 4L
