Old 21-01-2005, 06:53 PM   #1
FG8PSI
FG8PSI's Avatar
Question fuel system
hi all
i going to turbo my EL soon and want to know couple things, the most it will be is around the 10psi mark so what size injectors would i need and what size fuel pump.
and do i need to get a need ecu or will the one in the car be ok
thanks
Nick
FG XR8, 6spd auto, dual zone, sat nav, camera, leather, k N filter, Quad exhaust.
FG8PSI is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 08:06 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Yes you will need a new ECU or a chip for your ECU.
I would be going for 30# or 36# injectors, and you have a wide variety of options with the fuel pump. You can go in-tank, use the stock one as a lifter, than mount the aftermarket one in-line, remove the stock pump and fit the new one in-line, use the stock pump as a lifter for a swirl tank etc etc.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2005, 08:37 PM   #3
needfordspeed
Would those Ford motorsport injectors fit in a EL?These ones
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
