18-08-2005, 12:41 PM | #1 | ||
Formally knowen as EBus
hi all,
just a quickie, i want to change the ratio of my diff, to about the same as a ef - el, is this possible to do yourself? or how do you go about getting it done? cheers all
Car: :evilking: 91 EB Fairmont 3.9L :evilking: Changes: 5 spd manual Extractors, 2.5in exhaust AMG Quake 17's w/ maxxis rubba Lovelle superlows Cheap a55 Pod Filter Bike: CR250R 05 :evil3: |
18-08-2005, 12:43 PM | #2 | ||
PM me if you want
So you want about 3.45 with ot without LSD
18-08-2005, 12:45 PM | #3 | ||
The one and only
You can change the whole diff but you will have to change the handbrake setup.
the gears can be swapped but it is best to have it donr by a pro to set it up right.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
18-08-2005, 04:52 PM | #4 | ||
yep your on the ball dellboy, well i know stuff all about LSD, but the track i hit up has alot of corners, so what would you recommend lsd or not, and no i don't like or want to drift, i go for times.
how much would it cost (guesstimate) to have done what you stated LTDHO? cheers for your input guys
18-08-2005, 04:56 PM | #5 | ||
PM me if you want
I think around 500-700 to have a 28 spline diff (i think you already have) changed to 3.45 including gears, LSD will just stop one wheel spinning by default, and probably highly recomended
18-08-2005, 06:09 PM | #6 | ||
did u say the track you hit up?
what track? in your ea? hahahahahaha get a spool |
18-08-2005, 08:55 PM | #7 | ||
the ratio of your current diff Vs an ef/el will be about the same. What you wanna do is get an ED XR diff like Dellboy has said or get some skyline gears and an lsd center put into your current diff. XR diffs go for about 600ish, to rebuild it with new LSD and skyline gears will be about 900.
19-08-2005, 01:14 AM | #8 | ||
Doof Doof Operator!
I got a EB gli...think thats got gay slow diff! i was thinkin of upgrading to the 3.45 LSD or without...can ya just change the gears and u need new housing or from hub to hub or ?
EB2 Turbo & Territory SZ Titanium |
19-08-2005, 09:48 AM | #9 | ||
ah cool , cheers fellas, now i just gotta scab around and see how cheap i can get this stuff. would wreckers be a possibility?? or do you generally need to buy this gear new?
once again cheers for the advice
19-08-2005, 10:56 AM | #10 | ||
When you people say 28spline, are you saying that the axle splines on EB/EF are different??? So if i got gears from a EF sedan and put them in an EB wagon, id have to take the axles from the EF aswell? Do they all fit in?
Brent |
19-08-2005, 03:34 PM | #11 | |||
Last warning
lets not start abusing peoples cars.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
20-08-2005, 12:39 AM | #12 | |||
Doof Doof Operator!
20-08-2005, 12:42 AM | #13 | ||
why does your EBII have a 2.7 diff ?
20-08-2005, 12:43 AM | #14 | ||
Doof Doof Operator!
dunno isnt that wat is it standard? i forget it's something like that aint it?
20-08-2005, 12:45 AM | #15 | ||
EBII should have a 3.27.. :S
20-08-2005, 12:47 AM | #16 | ||
Doof Doof Operator!
hahaha hmmm mayb it does had 3.27...just checkn thru the gregory's manual! so i guess the 3.45 gears are piece of **** to change into mine then!?
