29-08-2005, 05:30 PM | #1 | ||
What inprovment do you get by putting these holes in speaker boxes?
29-08-2005, 06:08 PM | #2 | ||
are they there to inprove the base levels?
29-08-2005, 06:32 PM | #3 | ||
Missing the boost :(
pretty much.. its called porting i had planned to do it to mine but sold the subs so never did. but yeh basically of what i know its easier on the subs and gives it more punch :
BA XR6 Turbo
301rwkw mild tune Modified by XR6Turbo Developments |
29-08-2005, 06:33 PM | #4 | ||
would they do the same on 6X9 Boxes?
29-08-2005, 06:50 PM | #5 | ||
ummm.. well i wouldnt think so i could be wrong but i do know that with subs their sound quality depends on the air quantity in the box itself.
me and a mate had same sub set ups (two 12") his in a proper made ported box and mine in a smaller 'no ported' custom box and sound wise he sounded alot better and punchy! hope i helped somehow - super6
BA XR6 Turbo
29-08-2005, 06:52 PM | #6 | ||
you did thanks mate
29-08-2005, 07:03 PM | #7 | ||
It all depends on the type of subs you have some sound better with ports and some don't it should say on the installation directions. The old Sony xplod subs I had in my old corolla said best sound would be achieved by installing them in a air tight box.
HTH
1991 EB Fairmont: Wrecked 1993 ED Falcon: Gone 2005 BAII Falcon: Sold 2006 BF Falcon |
29-08-2005, 07:20 PM | #8 | ||
XR6 and XR8 Club of QLD
You don't just put some holes in your sub box and expect an improvement in response.
There are heaps of considerations - type and size of box, type number and layout of subs, diameter of port, length of port pipe - that's about all I remember. If you want a ported box, see a professional. Panda
Car - Ford Falcon XR6 Turbo |
30-08-2005, 07:12 PM | #9 | ||
Fairmont6
also ports are more for like an r&b type of bass it tends to drone for longer. if u listen to techno non ported is better it sounds more punchy
31-08-2005, 12:47 AM | #10 | ||
Does Steve have a car?
As said before, don't just drill holes in you boxes expecting it to sound louder. Ported boxes need to be tuned properly to get them to work. Often the box size will need to be doubled for a ported design to be effective, and then you will need to work out what size the port needs to be, both diameter and length wise, to get a good sound.
6 x 9's aren't designed to be boxed off at all, they are what you call an infinite baffle driver and work best when they are mounted into your parcel shelf (using the boot as an enclosure). For anyone not game enough to cut there parcel shelf, then the best thing to do is use spacers. Do you have a sub/subs?? Do you plan to get them?? The only time 6x9's should be used is when you don't have a sub. Once you get one, they lose any benefit they had, and you'd be much better off getting a set of 6inch speakers for the back...
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
