08-09-2005, 08:10 PM | #1 | ||
GMHKLA number plates
18 differant settings for your EF - EL try it on ur car
Turn key to first click holding down the odo button for 10 secs Turn to next click then release button and press 3 times On the Third press hold down till seat belt light goes out and release all i knw so far is setting 3 is ya digital revs read out to turn off and go bad to ODO repeat the above steps
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph 2000 Honda S2000 14.73@92mph (stock + no traction) Last edited by Age182; 08-09-2005 at 08:27 PM. |
08-09-2005, 08:31 PM | #2 | ||
V8 Powaah
* Post now irrelevant due to edited post above
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
08-09-2005, 08:31 PM | #3 | ||
If you go into the ford mods website you can find out what they all mean
http://www.fordmods.com/forums/portal.php |
08-09-2005, 08:48 PM | #4 | ||
sorry about that i worked out how to put it on
wer abouts on the ford mods website
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph 2000 Honda S2000 14.73@92mph (stock + no traction) |
08-09-2005, 09:30 PM | #5 | ||
Two > One
All ef/l ECU's can do this
08-09-2005, 10:48 PM | #6 | ||
can you do them on EB's?
08-09-2005, 10:57 PM | #7 | ||
try it ???
08-09-2005, 11:04 PM | #8 | |||
Get in the ring!!!
FG MKII XR6T - Tuned by Pit Lane |
08-09-2005, 11:31 PM | #9 | |||
*Smart *** comment here*
08-09-2005, 11:43 PM | #10 | |||
09-09-2005, 10:10 AM | #11 | |||
09-09-2005, 12:00 PM | #12 | ||
does eny one knw what the link to were on the ford mods website is for the 18 differant settings or does enyone knw wat they are ?????
09-09-2005, 01:13 PM | #13 | ||
EL/EF Diagnostics
Entering Diagnostic mode The diagnostic mode can be entered by using the following method 1) With the ignition key in the off position, press and hold the Odometer reset knob for 10 seconds. 2) whilst holding the button in, switch the ignition to the on position. (Note : It is not necessary to start the car). 3) With the ignition on, press the odometer button 3 times in quick succession. 4) On the third press, hold the odometer button down, until the Seatbelt lamp is no longer illuminated. · 5) The Odometer should blank out. After a period of 10 seconds, the display will flash FORD 6) Press the Odometer button again to go to the first Diagnostic mode To view the next diagnostic mode, press the Odometer button for about 1 second To view the previous diagnostic modes, press and hold the Odometer button for about 2 second To Exit the Diagnostic mode, hold the Odometer Button until the Odometer display returns to normal Mode____________Top Line_______________________Bottom Line . 1_____Petrol in Litres (No Level Buffering)_____Petrol Sender Resistance . 2_________________________________Coolant Temperature (Degrees C) . 3____________Engine RPM___________________Vehicle Speed (KM/H) . 4______Oil Pressure (Bar, 1 decimal Point)______Battery Voltage (Volts) . 5_____Instant Fuel Consumption (L/100Km)___I/Fuel Consum (x 0.1 Litres) . 6____Fuel used since Trip Avg L/100 Reset__Kms Trav since Trip Avg L/100 . 7_____Buffered Fuel Tank Level (In Litres)___B/Fuel Tank Lever Resistance . 8________________________________________Gear Position (PNRD321) . 9___________Unknown - 256__________Unknown - Varies from 00, 01, 02 . 10___________Unknown - 81____________________Unknown - 00 . 11______________0000_____________________________1 100 . 12______________1111_____________________________0 000 . 13______________0000_____________________________0 000 . 14________________________________________________ 00 . 15________________________________________________ 00 . 16________________________________________________ 00 . 17_______Illuminates all segments__________Illuminates all segments . 18_______Blank Odometer Screen______________Blank Odometer . Last edited by GenesiS; 09-09-2005 at 01:20 PM. Reason: formatting issues |
09-09-2005, 05:54 PM | #14 | ||
what are the advantages of this? i dont get it?
09-09-2005, 06:38 PM | #15 | |||
starter motor
09-09-2005, 07:48 PM | #16 | |||
09-09-2005, 07:51 PM | #17 | |||
not here much anymore
Temperatures etc can also be handy in fault finding or looking for issues with your car. The modes listed here are what Ford mechs use when servicing your car.
2024 F150 XLT
09-09-2005, 08:04 PM | #18 | ||
A V8 salute to my DEATH
hehe, i tried the speedo one and found my speedo is 5k's slow, but i also shat myself when it automatically returned to normal as the gauges all drop for a second. OOpps, what the hell went wrong. had me going.
1981 Toyota Hilux, 4inch lift, 33" Buckshot Mudders, LSD diffs, bullbar, driving lights, rollbar, toolbox and a 253 V8 |
09-09-2005, 08:08 PM | #19 | |||
Some people claim they can make their car stay in the mode indefinitely but in my EF it would only ever last 15 mins max.
2024 F150 XLT
10-09-2005, 12:14 PM | #20 | ||
thankz alot guys and thankz to GenesiS for putting the list there
10-09-2005, 02:00 PM | #21 | ||
Boooostn'
The diagnostic mode is just a function of the EF/L instrument cluster. So regardless of if you have EEC-IV or EEC-V in your EA-ED there is nothing you can view unless you have an EF/L instrument cluster.
2012 FPV GS Ute - Kinetic, Supercharged 5.0L, 6spd ZF auto, leather interior - The Boosted Daily! 1979 XD Fairmont Ghia - Silver, 302C V8, Full velour interior, slowly building her up to be a tough cruiser! 2002 Nissan Patrol ST - Desert Gold, 4.8L DOHC 6cyl petrol (Soon to be reequipped with a 5.7L LS1 V8), 5speed auto, lifted, locked, 33's, nature destruction vehicle! |
10-09-2005, 06:51 PM | #22 | ||
tuff
doesnt work on my el ,unless im doing it wrong
10-09-2005, 07:32 PM | #23 | ||
yea wat GenesiS got off the ford mods site is wrong i tryed it to do it like how i said to at the top of the page
11-09-2005, 03:01 AM | #24 | ||
Boooostn'
All you do is hold in the odometer while its off, then turn the ignition on, and depress it 3 times and hold it on on the third time and wait for the seat belt light to go off
the odometer should then go blank indicating its in diagnostic mode, just hit the button and it will change what indication it is on. to turn it off, just hold the odometer reset in and it will go back after a few seconds
11-09-2005, 11:28 AM | #25 | ||
mines not like that either mine to turn it on it only works how i said it and to turn it off i have to repeat those steps
11-09-2005, 01:11 PM | #26 | ||
Boooostn'
Well you are just prolonging how u do it, it doesnt need to take that long to do. You musn't be doing it correctly, because on every single EF/L i have done it on, it has worked that way, and everyone else I know does it that way, so I would say you would be the exception rather than the rule
11-09-2005, 01:24 PM | #27 | ||
On my EL when I found it in 99 on a Ford TSB it would stay on untill I turned the ignition off....
