Old 13-09-2005, 09:08 AM   #1
harry
harry's Avatar
Default best sway bars
Just wondering what sway bars you reccommend. im looking at getting front and rear sway bars.
Do you know much of a difference once they are installed?
harry is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 09:43 AM   #2
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
I recommend BIG swaybars. Ones that look like they've been made from a crowbar.
Will you notice a difference? Unsure - do you drive the car?
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 09:54 AM   #3
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Take a look at Whiteline's range, they have some big swaybars for E-Series falcons.
IMO, don't get a larger front bar without changing the rear bar, otherwise the car will have more tendancy to understeer.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 10:04 AM   #4
NZ
NZ's Avatar
I'm using whitelines 30mm adjustable bar. I don't really like their link system I've seen other designs which do the same thing but would be a bit more durable. But yeah 30mm sway bar definitly makes turning easier. The adjustable bar says it gives 115% stiffer over the normal 30mm bar but I don't know if thats the case. If i bought another it'd be the normal 30mm one. I guess the benifit is if you didn't like how stiff it was you could reduce it down a bit. The other davantage is you can set a different level of stiffness for each side - only for circuit racing though.
The sway bar was the biggest improvment in handling for me. perhaps on stock rims and average tires it would cause understeer thats something to consider. Someone like sox would be good for advice he seems to have a bit of experience with this stuff.
Old 13-09-2005, 10:08 AM   #5
NZ
NZ's Avatar
Also we installed my old v8 sway bar into silencers 6cyl ea. Even as a passenger i noticed it had a big improvment in turning. Body roll was reduced a fair bit. It really surprised me. Especially after we measured both the ea one being a smidge over 26mm and the v8 one 27.
Old 13-09-2005, 10:44 AM   #6
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
get a kmac one there huge !!!!
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
