Solution Was Boost 4?, 6 & 8
Hope this has been covered before, reading todays Melbourne Herald Sun Australia is getting a Ford Factory turbo Focus 165 kw Volvo Motor in this little sucker goes from 0 to 100 klm in 6.1 sec
![]() link web wombat story & pics here: there story says 162kw.. http://www.webwombat.com.au/motoring...ocus-st220.htm
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW Last edited by SpoolMan; 30-09-2005 at 10:02 PM. |
Weight: 1317 kg
Some more specs.... Engine Data Engine Type 2.5L 20 V DOHC Displacement (cc) 2522 cm3 Bore (mm) 83,0 Stroke (mm) 93,2 Fuel Type, Grade Unleaded, 98 or 95 (RON) Max Power (ISO KW/PS) 165.5 KW (225 PS) At Engine Speed (RPM) 6100 / MIN Max Torque (ISO NM) 320 NM At Engine Speed (RPM) 1600 – 4000 / MIN Compression Ratio 9.0 Cylinders 5, In Line Cylinder Head/Block Aluminum Alloy Valves Per Cylinder 4 Valve Gear DOHC with Direct-Acting Mechanical Shimless Tappets Turbocharger KKK – Warner Integrated Turbo System Engine Management Bosch Motor Management System Fuel Injection Sequential Electronic Fuel Injection (SEFI) Ignition Electronic Distributorless Emission Level European Stage IV, With Electronic On-Board Diagnostics (EOBD) Transmission Transmission Type Manual 6-Speed Clutch Type Single Dry Clutch and Dual Mass Flywheel Suspension Front Suspension Independent MacPherson Struts with Offset Coil Spring Rear Suspension Independent Short-Long Arm (SLA) Control Blade Mulit-Link System Steering Type Rack and Pinion, Ratio 14,8 Turning Circle (M) Kerb-to-Kerb: 11.7 Brake System Dual-circuit, Diagonally Split, Hydraulically Operated Discs Front and Rear. Vacuum Servo-Assist. Standard Electronically Controlled Anti-Lock Braking System (ABS) with Electronic Brake force Distribution (EBD) and Optional Electronic Brake Assist (EBA) System Front 320 x 25 mm Ventilated Discs Rear 280 x 11 mm Solid Discs Wheels/Tyres Standard Wheel Type Cast Aluminum Alloy Standard Wheel Size 18 x 8 Tyre Size - Standard 225/40 R18 Exterior 3/5 DR Overall Length (mm) 4362 Overall Width (mm) 1840 Overall Height (mm) 1497 Wheelbase (mm) 2640 Front tread (mm) 1535 Rear Tread (mm) 1531 Weights 3/5 DR Basic Kerb (KG) 1317 Gross Vehicle Mass (KG) 1860/1890 Payload (KG) 543/528 Luggage Compartment (VDA) L 385 Targeted Performance And Fuel Economy Max Speed (KPH) 241 Acceleration 0 – 100 KM/H (secs) 6.8 0 – 60 mph (secs) 6.5 Flexibility 50 – 100 KM/H (4th) (secs) 6.1 Fuel Consumption Urban (ECE L/100 KM) 13.8 Extra Urban (ECE L/100 KM) 6.8 Combined (ECE L/100 KM) 9.3 CO2 - Combined Mode (G/KM) 224 |
not here much anymore
this would be bloody right, literally the day after i said i wouldnt buy a ford again. Dammit now I have to take back that statement........
2024 F150 XLT
Supes
I am sure it would be an awesome bit of gear.....but, the article doesnt mention any delivery to Australia for the ST.
If the last ST deliveries were anything to go by about 200 would make it our shores ![]()
Yes I DO drive a Toyota |
#5 | |||
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
time to save up....
but how much do u think it is? |
Giddy up.
MMMM I can't wait for this little pocket rocket, WRX eater.
#8 | |||
Zetec Screamer....
Any thoughts? Tom
White 2004 Ford Focus Sparco Gear Knob & Aluminium Pedals, 2 1/4" Mandrel Bent Magnaflow Cat-Back Exhaust with 3" SS tip, Full Ford Body Kit with Zetec R Spoiler, K&N panel filter
#9 | |||
[SIGPIC][/SIGPIC]
Zetec Screamer....
yeh, thats my only concern. Just pricing it up against some of the other hot imported turbo cars out there and their prices.
I mean, a volvo s40 T5 (where ST parts originate), falls just short of $60k, before on roads. I would sure like to own one of these beauties, but if the price aint right, then obviously i cant afford it. Tom
Giddy up.
For that price forget it, I'll pass.
#12 | ||
Blinded
It's have to be below $40K to compete with Golf GTI and RenaultSport Megane 225. I wouldn't use the Volvo T5 as a benchmark, there's much more kit in the Volvo.
Now, question is, would I want to buy another orphan hot Ford? |
#13 | |||
Official AFF conservative
Awesome to see they're releasing it tho. Serious piece of kit!
A cup half empty... but full of euphoria. |
#14 | ||
likes falcon's
pretty heavy for a little car
www.carhubsales.com.au |
#15 | ||
Yeh im not surprised about the weight, the thing is full of equipment and its a gorgeous thing, the times are good, and its supposed to handle better then the Mk1 RS.
Pricing is i think $37,000 - $39,000. |
#16 | ||
WRC Fanatic
If we use the UK prices as a guide, you will find that the new ST should not cost anywhere near 50 - 60k.
In the UK the ST170 typically retailed from £15995 pounds and for $37000 in Oz. The new ST starts from £17495, so I think it would reasonable to expect a price of between 40k and 43k when it arrives in Oz. The car looks fantastic, has a great interior, will have brilliant acceleration and even better handling than the current ST ....er hang on..even better handling? is that possible? ![]() Dunno about you, but at just over 40k, I reckon it'll be a bargain! Guess I had better start saving then.....
Panther Black XR5T Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph |
#17 | ||
XR5T - Sea Grey.
I'm putting money in the piggy bank as we speak!
#18 | ||
Giddy up.
The ol ST170 was around $41 wasn't it, if it is around that price, it won't be to bad, around the same price for a WRX too.
#19 | |||
WRC Fanatic
The St170 was $37 000.
#20 | |||
Giddy up.
#21 | |||
Zoom Zoom
2012 Mazda3 MPS
#22 | ||
Is this a FWD, RWD or AWD? Talk about a pocket rocket! Couldn't they fit another cylinder in there? Or would that stuff up the name and the XR6T market? lol
Imagine that...XR6T in a 1350kgs chassis... Still a bit of tinkering and this thing would be insane...
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#23 | |||
beep beep
Nothing to see here, move along, move along... |
#24 | ||
beep beep
Conversion rate puts the base ST at about AU$41,500 Then there is the ST2 and ST3 which have higher levels of internal trim.
Now - don't forget England have higher levels of taxation of cars than in Australia, so without taxes it could be say $35,000, then with import excise or whatever could be about $37,000. I figure it will be priced similar to the ST170 - and other cars in that market from Europe.
#25 | ||
I'll be signing for one. When I dont know but I guarantee it will happen.
2024 F150 XLT
#26 | ||
Id love one... Im guessing it would be priced between 35k and 40k....
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
#27 | ||
GT4.
Time to forget about getting a VW golf GTi then..... its a whole second quicker, and not far off the Typhoon and GT pace
#28 | |||
Its nurburgring times well a full 10 seconds quicker than the Mk1 RS. |
#29 | ||
Would be a very nice addition to the garage.
But I am thinking that it would be more around the 40-45k mark. |
#30 | ||
Interesting to see HSV announced the release of the VXR (read Opel modified Astra turbo coupe) at the same time.... I think it's got a few kw over the Focus. Interesting times ahead, the sales battle will be hot! http://www.hsv.com.au/vxr/vxr.html
VXR has stuff like Recaro seats and 19" alloys standard too. Has Ford Australia got anything out officially yet on their website? Are FPV selling it, or Ford? edit on other thread: http://www.ford.com.au/newfocus/xr5/ and it has Recaro seats standard too!
2016 Kuga Titanium 2.0l EcoBoost Last edited by murcod; 14-10-2005 at 09:35 PM. |
