03-10-2005, 04:35 PM | #1 | ||
EFXR custom
Fully rebuilding EF and debating over engine rebuild. Have considered the JMM DEV5a kit but also have the opportunity of getting a motor, gearbox and all bits from a wrecked BA. Does anyone know of any engine swaps and what needs to be changed to fit the BA 4.0L. Have heard that crossmember is an issue but have seen several cars in Magazines with the transplant done. If successful will add Vortech supercharger to aim at 300kw.
03-10-2005, 04:38 PM | #2 | ||
PM me if you want
do a search on these forums for 'jetxr' , you will answer most of your questions as to fitting the BA 4.0L
03-10-2005, 04:50 PM | #3 | ||
*Smart *** comment here*
yeah i have a few articales on that jetxr here at home in strreet machine and performance fords... that thing is nuts... theres a lot of mods, probably the most obvious one to the outside world is you won't be able to close your bonnet with the BA engine in it... the jetxr had a hole cut in the bonnet, but the way it was done it looked awesome...
03-10-2005, 04:51 PM | #4 | ||
PM me if you want
JETXR is also not engineered certified, nor has it been registered due to this fact.
03-10-2005, 04:53 PM | #5 | ||
Last warning
it is registered.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
03-10-2005, 04:55 PM | #6 | |||
03-10-2005, 04:59 PM | #7 | ||
Last warning
does installing a later model engine require engineering?
the turbo install is fine since it was standard on the engine, but i'm not sure what the legalities are with the later model 4.0 being installed. either way, theres plenty of other things not legal on that car so i doubt they care :P
03-10-2005, 05:20 PM | #8 | |||
Does Steve have a car?
AKA Mr Silver Chasing reliability....: "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
03-10-2005, 05:23 PM | #9 | ||
Last warning
shoulda guessed you'd know
03-10-2005, 06:50 PM | #10 | ||
BASS ON BOARD!
i believe he lowered the engine mounts and the bastard still didnt fit!!!
EL .....BA TURBO ......the mind is in overload
Nothing interesting to put here. |
