26-10-2005, 04:11 PM | #1 | ||
Shoot.
I know I've asked a million people a million times on MSN, sorry guys! But I am still left confused regarding timing.
I have just replaced the head on an EF, and I want to put in the cam and rocker gear now. However, engine is not on TDC (about 5 degrees off). The chain is cable tied to the sprocket (done at beginning). Timing chain tensioner hasn't been touched. I didn't mark anything. Can I just put the cam in without any problems? Or do I HAVE to have it on TDC etc? Please spell it out for me, coz I'm still an amateur!! Thanks
20V Turbo |
26-10-2005, 04:14 PM | #2 | ||
Will be fine as is, just put it back together.
If you haven't removed the gear from the chain it'll be fine.
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
26-10-2005, 04:21 PM | #3 | ||
burn out king
so you dident remove the tensioner when you pulled the thing apart? wont go back together with the tensioner in there
26-10-2005, 04:24 PM | #4 | ||
You should retreact the chain tensioner as it may have come out to far when you pulled the cam sprocket off. when you put the new cam in releace it to take up the slack in the chain
26-10-2005, 05:02 PM | #5 | ||
Shoot.
Thanks so far guys. Two questions though:
How do people manage to get the sprocket back on without releasing the tensioner? If I have to loosen the tensioner, do I just need to keep the sprocket UP (ie. broom handle trick)?
20V Turbo |
26-10-2005, 07:22 PM | #6 | ||
GMHKLA number plates
ive done it at work im a second year appprentice mechanice and it is posible im in the middle of doinhg my cam n i wont be backing off the tensioner as i can still get it back on
note: i tryed it on mine before i took the cam out
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph 2000 Honda S2000 14.73@92mph (stock + no traction) |
26-10-2005, 07:24 PM | #7 | ||
eec tweaker
i unbolt the tensioner totally from the block, its easier than dicking about with allen keys.
as a tip, turn the motor over by hand when you're finished to make sure everythings sweet. Jase |
26-10-2005, 08:34 PM | #8 | ||
Shoot.
I released the tensioner in the end. I don't think anything slipped etc. Now I just have to assemble the mofo together and cross my fingers. I'll probably be on here complaining that something smashed through the side of the head LOL!
20V Turbo |
27-10-2005, 08:05 PM | #9 | ||
Shoot.
Well you wouldn't believe it! Fired up straight away (after a new battery $#%@!). So ****ed off though, I didn't do up the bottom radiator hose tight enough!!!
20V Turbo |
27-10-2005, 08:09 PM | #10 | ||
Last warning
good to hear
amazing how easy it is eh ;)
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
27-10-2005, 09:32 PM | #11 | ||
Two > One
Bah to removing the tensioner. You lot are soft
27-10-2005, 10:20 PM | #12 | |||
haha right on! ;) I've never released the tensioner despite what the Ford book says etc. Just use a big *** screwdriver to lever the cam sprocket back on. |
28-10-2005, 02:24 AM | #13 | ||
burn out king
roots the slides tho. but the way you blokes go throu head gaskets it dont matter
28-10-2005, 09:54 AM | #14 | ||
Too much tension can also cause the dizzy drive shaft to seize up. It doesn't have a bearing , just oil to lube it. Sox hat to scrap his xh block from the hole being worn and he said too much chain tension was the probable cause.
28-10-2005, 01:31 PM | #15 | |||
Two > One
