03-11-2005, 06:17 PM | #1 | ||
In a recent post about the new VE SS making 300kW, I read someone mention that the 5.0L Windsor was detuned....I have the 165kW engine in my ute so if anyone knows how to match the performance of the XH XR8 185kW engine using factory parts it would be much appreciated. So far I know that the intake manifolds were bigger on the XR8
Chris
1998 XHII S Longreach V8 - 16.648 @ 133.65km/h -XR8 Rims -Blackout Tint -Pioneer HU |
03-11-2005, 06:24 PM | #2 | ||
Last warning
the 185's got better exhaust manifolds too.
the maf and t/b may have been bigger, not sure.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
03-11-2005, 06:26 PM | #3 | ||
meow
That extra 20kw comes from a completely different inlet manifold. Explorer as opposed to HO. These are found on ELII - AUIII
Im not sure but was there also a Throttle Body change? |
03-11-2005, 06:53 PM | #4 | ||
hey this might fit into this thread...
what is the difference between the fairmont V8 ( AU's ) and XR8's? is it possible to get the fairmont up to the same standard as the XR? cheers rob |
03-11-2005, 06:58 PM | #5 | ||
windsor user
read this thread
http://www.fordforums.com.au/showthread.php?t=25689 everything you need to know about what came with what obviously the most acurate info will be at end of the thread as it gets corrected...... |
03-11-2005, 10:27 PM | #6 | ||
overdriven
get hold of 347stroker. he knows a fair bit
04-11-2005, 11:26 PM | #7 | ||
Windsor - order the "GT40" intake kit from the USA along with a bigger MAF and TB. Put an E303 cam in it, a set of 1.7:1 roller rockers (these are awesome when combined with the "E" cam), a good set of headers and a nice flowing exhaust and get it tuned. Parts from the US should come in at about A$1,000. Add the cost of the pipes and the labour (depending on who you know) and you could be boogying for A$3-$4K.
05-11-2005, 11:16 AM | #8 | ||
GT40 Kit? Where can you get that? I heard with the GT40 heads and valvetrain and cam you can make about 250kw? My engine does the job for me at the moment, but like most people I am bored with the power and want more, but rather than buying aftermarket stuff I want to try and keep the engine bay looking stock. Is the GT40 kit a Ford item? Would a good start be to get the XR8 MAF and TB as these are ford items?
05-11-2005, 12:04 PM | #9 | ||
My little windsor in the ute (XHXR8) is fantastic, and it is nothing special.
All I have done is 1.73 Y/T rollers T3 TE50 Cam Under Drive pulleys 24lb injectors Pro M Maf suit 24's Stock GT40P heads GT40 Lower Cobra upper 65mm T/B ELGT extractors 255lph Walbro in tank pump Kirban Adj Reg 3.45 T5 I have real trouble on a wet road, when it hit 3700 rpm, in 2 or 3rd gear, it just buzzes to 6000 and blazes the tyres, will smack a Gen III VYSS manual, and the other night, one of the members from here, in his Fairmont Ghia I6 came up next to me at a set of lights. I tow a big trailer, very un aerodynamic and across the scales, GCM of ute, trailer and me is 2684kg, with half a tank. By 3rd gear @5500rpm, I was about 15 metres in front..... The cost to get these things going hard is stuff all. All up I have probably spent $2500 on it. |
05-11-2005, 05:53 PM | #10 | |||
Peter Car
05-11-2005, 06:13 PM | #11 | ||
windsor user
have to agree with bossxr8.
you wouldnt have very much change from a grand for just the GT40 upper and lower and a TB. then the cam, rockers and maf etc would easily bring that up to 2k, thats without changing heads.... then there's the labour if you arent mechanically minded enough to install it all |
05-11-2005, 06:44 PM | #12 | |||
I know how much the parts cost because I have gone through the exercise for myself and several others. Do yourself a favour - download the Ford Motorsport catalog and then pick the dealer you want to buy the stuff from. I can even give you the details of my contact - he will do you anything at cost plus 10% from the Ford parts bin. Oz |
06-11-2005, 09:43 AM | #13 | ||
Oz Dude,
Where can I get a hold of the ford motorsport catalogue? Cheers
06-11-2005, 09:49 AM | #14 | |||
Clevo Mafia Inc.
That's dam impressive bang for buck, have you had it on a dyno ? |
06-11-2005, 10:10 AM | #15 | ||
347 Stroker,
Say I used the following, -ELGT Extractors -T3 TE50 Cam (5.6L ?) -Stock GT40P heads (Ill assume these are the ones on the windsor already) -GT40 Lower (Intake manifold?) -Cobra Upper (Intake manifold?) -65mm T/B With the exception of the cam, are these parts bolt on (no tuning rewiring etc) and would I need to upgrade the fuel pump, how much it would cost to buy, how much power I could make and where I can get these parts? My last question, is it possible to make 250fwkW using the parts you have? Thanks
06-11-2005, 10:13 AM | #16 | |||
Back on the road
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
06-11-2005, 11:07 AM | #17 | |||
06-11-2005, 11:39 AM | #18 | |||
RDP #181
So did you figure out what the deal with the thermactor tubes are? do the just need to be blocked off? I was looking at some crate motors in a mag and some make specific mention of the thermactor tubes while others dont.
06-11-2005, 11:52 AM | #19 | |||
06-11-2005, 12:49 PM | #20 | ||
Does anyone have part numbers for the items I listed above?
06-11-2005, 02:53 PM | #21 | ||
I have figured out the block off plugs, and now have them, so hopefully I can get them on next week, seeing that its my work ute, I cant have it off the road too long, but can get a tow bar fitted to the EF, and use it....hmmmm
I dont want to sell anything either mate, all good stock for the EF when it eventually gets a Windsor conversion.... |
06-11-2005, 08:35 PM | #22 | |||
Peter Car
06-11-2005, 09:57 PM | #23 | |||
Clevo Mafia Inc.
06-11-2005, 10:04 PM | #24 | ||
Grinder+Welder = Race car
I can guarrantee its a 5.0!
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Too much power is never enough....Mark Donohue on the Can Am Porsche 917. |
06-11-2005, 10:08 PM | #25 | ||
"We are not afraid of the Clevelands. Windsors have condemned them. They are stupid. They are stupid" (dramatic pause) "and they are condemned."
07-11-2005, 01:39 PM | #26 | ||
How can I tell which parts in the catalogue are suitable for my EEC-V 5.0L? Most are for the 83-95 mustang 5.0 Cobra....
07-11-2005, 01:48 PM | #27 | |||
09-11-2005, 08:47 AM | #28 | ||
anyone else know?
09-11-2005, 09:26 AM | #29 | |||
Official AFF conservative
Some pls clarify - but you'll probably need to do some mods to the throttle body if you buy one from US as the linkages are on the other side (look at the fitment of a US manifold compared to ours and you'll see what i mean).
A cup half empty... but full of euphoria. |
09-11-2005, 11:48 AM | #30 | ||
Performance moderator
I bought that kit along with Cobra eec, inlet, maf injectors,E303 cam, throttle body but TFS heads around 1997 for my E.B ..I only have the throttle body now...
It was the same as 93 Cobra Mustang motor..Similar to Sprint/ G.T....
