Old 28-11-2005, 05:05 PM   #1
darnoldrs
Default Auto/Manual conversion/ cruse problem.
I have bought a EL XR8 which has been converted to manual however when the cruse is on and you push in the clutch it doesnt dis-engauge. Is there an easy solution to this or is the manual/auto cruses slightly different??? Thanks, David
darnoldrs is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2005, 05:17 PM   #2
vegabass
BASS ON BOARD!
vegabass's Avatar
its missing the switch off the clutch pedal. i welded a old brake switch off a EB pedeal box and i havent wired it in yet but ill get around to it one day.
Im just going to find the cruise wire that is on the brake pedal and wire it up to that.
*Note on the left hand side of the steering the welded tab with the black switch in it its a little hard to see as i painted it silver before i put it back in.....because people are always looking under my dash........ : :
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 12:03 AM   #3
darnoldrs
Thanks for that. My cousins XH ute, when he pushed in the clutch in it reved up about 200rpm then dis-engauged and didnt know if there was a switch missing or if it was programed different. I will have to have a look and if its not to much troble i will track down the wires needed.(im a TV tech so it should be ok) Thanks again, David
Old 29-11-2005, 12:42 AM   #4
vegabass
BASS ON BOARD!
vegabass's Avatar
Let us know how you go, and how you wired it up. so i can do it as well.....when i get off my *** and do it!! sleep:
Old 29-11-2005, 07:45 AM   #5
darnoldrs
when i get off my *** and do it!! sleep:[/QUOTE]
This has been my problem also. I havnt even taken a look under the dash at it yet. Ill get to it this week i hope.
Old 29-11-2005, 10:13 AM   #6
stockstandard
On my EF there was a plug ready for the clutch switch. When the car is auto there is just a loop (green/red wire if I remember). Need to cut this loop and wire the two ends to the clutch switch.
Old 02-12-2005, 09:20 PM   #7
TwistedEL
TwistedEL's Avatar
If I remember correctly on an auto the connector for the clutch switch sits up behind the fuse panel capped off.
Old 03-12-2005, 01:01 AM   #8
oneredED
need more boost
oneredED's Avatar
I used a Mal Wood pin to do the clutch pedal in my ED, and so there's no bracket to hold the clutch switch for the cruise, one trip to 6000rpm, and i barely every use cruise now... I'm going to try and weld up a bracket to mount it, but cant be stuffed at the moment...
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
