Old 02-12-2005, 02:45 PM   #1
fatxagt
fatxagt's Avatar
Default AU head gasket on 3.9?
I am changing the head gasket and maybe the head tommorow on the NA2. Is it better to use the AU gasket or stick with the original one? Will it fit striaght on with the same tourque settings? Thanks for any help!
fatxagt is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 03:52 PM   #2
naughtyfalcon
both will do the job,just depends on how much you want to spend
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 04:57 PM   #3
EFFalcon
Last warning
EFFalcon's Avatar
most will recommend the AU headgasket.
the torque settings are slightly different.
AU is 30nm + 120 degrees
the older gaskets are 40nm + 90 degrees.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 02-12-2005, 04:59 PM   #4
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
Go the AU for sure.....but remember your compression will be slightly higher...so might need to run premium ULP to run 100%
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E
Tuned by Michael J's & Son.
EASPRINT is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 05:02 PM   #5
EFFalcon
Last warning
EFFalcon's Avatar
i'd imagine an AU gasket on an EA (8.8:1 compression stock) wouldn't exactly give it a need for premium.
also nothing some timing adjustments can't fix.
Old 02-12-2005, 05:06 PM   #6
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
true, but depends if ya chasing performance?. U can gain power using the AU gasket if u tune on PULP.
Old 02-12-2005, 06:34 PM   #7
5speedeb
now with 3.73 lsd
at work we use
stage 1 40nm
stage 2 80nm
stage 3 110nm
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 08:11 PM   #8
fatxagt
fatxagt's Avatar
Dont peed performance , just reliability. I have a XA GT for Performance. Thanks for your info guys. Are the single point and multipoint head the same?
Old 03-12-2005, 01:18 AM   #9
INJECTED_250
Custom user title
INJECTED_250's Avatar
pretty much much as long as its not 3.2
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
