Old 16-12-2005, 06:16 PM   #1
ST09RM
2011 FG XR6T UTE
ST09RM's Avatar
Default Water jets..
hey today i brought those water jets which are silver and at night they go red if connect to the battery i think...i own a EF and im justing asking how the hell do i install them? ive got no idea and how do i remove the old ones?
ST09RM is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 10:07 PM   #2
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
I think we need more information, pics maybe. are you takling about the LED window jets
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 10:18 PM   #3
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
im pretty sure you can get defected for them so be carefull.
ive never fitted them cos .. well .... they look rice dude...but its your car and they cant be too difficult to fit cos i see them everywhere..
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 10:28 PM   #4
Blue Oval Mopar Man
Has Blue Blood
Blue Oval Mopar Man's Avatar
Coool !
Did you buy them from this speed shop ?
http://i21.photobucket.com/albums/b2...an/CloseUp.jpg
Real cars dont wear bowties
I'm not arrogent , Just superior
Blue Oval Mopar Man is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 10:43 PM   #5
lukey
www.lukehimself.net
lukey's Avatar
Just run a cigarette light plug off it and put it through a hole in the firewall so you can plug/unplug it when people tease you about it and you decide to turn them off.
Subaru Liberty MY04 4GEN Luxury
www.lukehimself.net
lukey is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 10:59 PM   #6
crannersEL
crannersEL's Avatar
Also a good idea for when you see the cops, at leist that way you have control of them being on or off. Even set up a switch inside the cabin somewhere.
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2005, 11:32 PM   #7
AnthonyQLD
Boss power
AnthonyQLD's Avatar
If they are red ones you will have trouble with the boys in blue. If they were white you can get away with it (sometimes).
AnthonyQLD is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2005, 01:56 AM   #8
SUX350
Did"nt they come with instructions..
SUX350 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2005, 08:53 AM   #9
Casper
Contributing Member
Casper's Avatar
Probably.. something like:
1.Put on beanie
2.Connect fully sik lights to power (get ya mates to help yaz)
3.Place seat in fully laid back position
4.Do some laps with ya boyz
(dont forget to get the matching rice cannon neon exhaust tip)
Older, wiser, poorer.
Old 17-12-2005, 09:06 AM   #10
LUXO_8
windsor user
1.Put on beanie
gee shane, sounds like you've bought them before, did you read that straight off the instructions sheet??
Old 17-12-2005, 09:11 AM   #11
Casper
Contributing Member
Casper's Avatar
Nah, I got the full "knight rider" neons in the front.. same stuff :
Old 17-12-2005, 10:24 AM   #12
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Red lights at the front of the vehicle are illegal, don't waste your time putting them on as they will have to come straight off again...
Old 17-12-2005, 10:51 AM   #13
wulos
Forum Director
wulos's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind-the-scenes effort. Technical Contributor: For members who share their technical expertise. - Issue reason: For his advice, tips/tricks in the Art and Photography section of the Forum.
sheesh - talk about opinionated bunch of people!!!
As they say, each to their own, it's NOT YOUR CAR he wants to put them on.
If that's the route someone chooses to modify their car well & good, there is NO rule book that says what is good & what is not.(if there was I dare say that EVERYONE on here woulda fallen foul of the rulebook at one time or another)
Apart from the legal aspect, that you should be aware of so as to not get yourself unwamted attention. Read the following.
On most cars the original washer jets are a push in clip type arrangement that springs outwards. To remove these you will most likely need to remove hood lining under bonnet (if fitted), remove the tubing(should be a push on 'spur' type fitting, then use a pr of long nose pliers or the like to push in the lock tabs on the underside of the washer jets. Don't be too suprised if you butcher these whilst trying to remove them.
To fit the new washer jets I would hazard a guess that they're larger then the originals, & may have a locknut & wiring that you will need to enlarge the size of the holes in the bonnet to enable correct fitment. Use drill(may need to be larger then expected to provide clearance for spanner to tighten nuts etc) to enlarge hole on underside of bonnet, being careful NOT to go through the outer skin.
The wiring should be done in looming that provides additional mechanical protection (split, spiral looming etc) & routed back to the cabin via glanded bushing through the firewall. Connect wiring to a switch & fused circuit & you should be right.
As you can prob see there would be a fair bit involved, but if thats what you want, & it's all legal, then go for it.
wulos is offline   Reply With Quote Multi-Quote with this Post
