Old 20-12-2005, 07:16 PM   #1
Dti-dan
Default 4L with 3.9 head?
hey guys i was woundering if it is possible to use a 3.9 mpi head on a 4l block? i had a bit of a search and apparently the AU head gasket is the best to use?
the reason for this is i have a ea on gas and it has done a bottom-end bearing and the gear box is a bit tired. but i have access to a inj 4L with good box.
any information will be muchley appreciated
dan
Old 20-12-2005, 07:26 PM   #2
CruizinEB
yes you can put a 3.9 mpi head on a 4l block, it gives you better compression
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 07:28 PM   #3
niko
likes falcon's
niko's Avatar
try find an eb head they "flow" much better
www.carhubsales.com.au
Old 20-12-2005, 07:30 PM   #4
LUXO_8
windsor user
if you have the complete 4litre and good trans, just put that engine in,
Old 20-12-2005, 10:43 PM   #5
Dti-dan
thanks guys
MADNC_8 i wanna keep the 3.9 head cause of the mpi smd itd on gas
Old 20-12-2005, 10:54 PM   #6
Damo
the head are the same for MPI and CFI.
Old 21-12-2005, 02:21 AM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
Yep just change inlets etc..
Daily driver GTE FG..
Old 21-12-2005, 08:25 AM   #8
EA2BA
PM me if you want
EA2BA's Avatar
I have an EF 4L block with an EA 3.9L head and Au head gasket all bolted together in the car just waiting to be started, so it is 100% possible
