Old 14-01-2006, 03:21 AM   #1
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
Default stall converters in... problems....
Hi,
Well i finally got the bastard in lol... Anyhow..
Its stalling up nicely but when launching, it feels like its slipping but the revs will not raise.... This is at about 3100rpm at wot...
Now it will catch when i stall it a little lower and then release, but not when i stall it up a bit more...
Now im hoping its not the box(or stally), because i absolutly hate working on boxes...
Could this be due to leaning out??? I mean its not slipping (revs going up and down.. etc)
Please tell me its due to a lean tune lol... ???? :newangel: :newangel:
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 08:43 PM   #2
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
It wont do it if i just plant it from the lights, but when i stall it up to about 2 grand, and then let her rip, the tyres will smoke and then all of a sudden the tacho will just stop at 3200rpm, but still be pushing the car...
Anyone?? any ideas?? I dont think leaning is the problem unfortunately....
Cars:
- XY GT Replica
- XB Coupe Project
Old 14-01-2006, 08:47 PM   #3
Casper
Contributing Member
Casper's Avatar
This is normal. The stall will "stop" at the peak stall rpms until the roadspeed catches up. Once the roadspeed catches up it will then climb again. Mine does it too.
Older, wiser, poorer.
Old 14-01-2006, 08:59 PM   #4
INJECTED_250
Custom user title
INJECTED_250's Avatar
thats exactly how a hi-stall works... :>
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 09:14 PM   #5
Casper
Contributing Member
Casper's Avatar
yup..
Old 14-01-2006, 09:26 PM   #6
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
sorry fellas.... it was LHM...
I dont think stall converters are supposed to lock up at 3100rpm for 300m lol
I will try a bigger trans cooler and see how it goes...
Im a bit worried though... because its doing this even when the oil is cold(ie, cold motor)
Cars:
- XY GT Replica
- XB Coupe Project
Old 15-01-2006, 01:20 AM   #7
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
How old is the box? Has it been re-built?
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 01:16 PM   #8
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
its been serviced a few times... not rebuilt
maybe i should try another service?
Cars:
- XY GT Replica
- XB Coupe Project
Old 15-01-2006, 01:27 PM   #9
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
It sounds like the stall is too big for the ECU. They often go into LHM with stall speeds over 3000rpm.
Old 15-01-2006, 01:52 PM   #10
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
yeh, how can i change that??? are you sure? because there are plenty of people going around with a 2800 stall....
Cars:
- XY GT Replica
- XB Coupe Project
Old 15-01-2006, 03:11 PM   #11
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Either by launching at lower RPM, changing the convertor, or maybe fitting a trans chip to the ECU/TCU and altering a few of the settings and you might be in luck.
It's been fairly well documented on the forum EEC, and especially E-Series EEC don't like seeing stall speeds over 3000rpm.
Old 15-01-2006, 03:25 PM   #12
LUXO_8
windsor user
silly little thing, but are you sure you have enough trans fluid in it.......
Old 15-01-2006, 03:36 PM   #13
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Yes I'd be double checking fluid levels too. Also try doing the ECU Self-Test listed in here: http://www.fordmods.com/forums/documents.php?doc=52 - It should tell you why it's going into LHM.
Normally the BTR boxes can handle high outputs with a few mods quite well, but the factory does seem to have averge QA, and the quality between transmissions is quite varied. If it doesn't already have one, have you fitted an AU S5 adjustable solenoid? You can adjust line pressures with it, which alters shift speed.
Old 15-01-2006, 03:56 PM   #14
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
naa to be honest i dont know much about boxes, all ive dont is throw the 2800 tce or tge stall in it, and put a bigger cooler on it...
the stall works nicely, but when in drive, and when i stall it to about 2100 and then let it go, it goes into LHM...
So i will give a service a go (new oil, filter).... if not, ill do the self test.
Ive got ems on the way but i was planning to have the stock comp control the autos....
i will look at the AU solenoid though.. what do you guys think of those cheapo shift kits??
Cars:
- XY GT Replica
- XB Coupe Project
Old 15-01-2006, 03:58 PM   #15
LUXO_8
windsor user
i dont think the cheapo shift kits are worth it on an engine thats being worked personally. do it propperly with a propper shift kit
Old 15-01-2006, 09:46 PM   #16
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
yeh i thought a little too good to be true.. however, there have been quite a few people have them for a while and no probs...
anyhow, was fiddling before and it wont do it when i have it in 1st gear, but will do it when i have it in drive.. so im not sure if this means anything but thought id tell..
Cars:
- XY GT Replica
- XB Coupe Project
Old 16-01-2006, 07:56 PM   #17
galapogos01
eec tweaker
galapogos01's Avatar
so is it trying to shift out of 1st at those revs for some reason?
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
