Old 10-02-2006, 10:48 AM   #1
ilsautomotive
Former E-Series Member
Default Email Help Request II
Im not sure if you can help me but its worth a try.I own an NA series II Multipoint injected 6cyl and for some reason it seems to be idling rough but only when it is in drive.Say for instance in my driveway in neutral it will be fine sitting at about 1000rpm.At the lights in drive itll be revving about 600rpm and be a bit shakey.as soon as a put my foot down it surges before driving perfectly fine again.Its recently had new plugs,fuel and air filter and while i was at it i cleaned out the throttle body the rotor button and distributor cap appear to be in fine order.Auto fluid looks fine and the exhuast system has been replaced but yet the problem still persists. the only things i can think of is either bad fuel (Car had been sitting around in a car yard for around a month) or the coil has had it.Ive checked for a head gaskett problem ie milky oil or coolant and it all appears to be fine.If you have any ideas please do let me know.I work at Tyrepower and the mechanics seem to be baffled and have no idea (either that or too lazy to help).I have filled in a request for membership on the site and hope to be a full member of the club very soon.Anyway thank you for your time.
FROM Nathan (NATH)
Old 10-02-2006, 10:52 AM   #2
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
I would probably say coil.
I remember in my old EA that when the coil went, along with the dizzy (CFI, not MPFI), that it did the same sort of thing.
Carless
Old 10-02-2006, 11:24 AM   #3
hako
hako's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Regularly gives valued, considered advice to others.
It shouldn't be sitting at 1000rpm in neutral - more around 700rpm so that is a clue ( but I dont know what for). Our EB MPFI also suffers from an initial hesitation when in first gear.
hako is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2006, 11:29 PM   #4
Nath
NA Series II
Nath's Avatar
Thanks for the advice.Will have to check those things out.Probably a good idea i replace the coil anyway considering i just brought the car and i dont know when it was last replaced.Thanks again.
Nath is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 12:36 AM   #5
hako
hako's Avatar
Maybe also put a bottle of injector cleaner through the tank.
Old 11-02-2006, 06:08 PM   #6
Nath
NA Series II
Nath's Avatar
Sorry meant 1000rpm in park not neutural.
Old 11-02-2006, 06:20 PM   #7
Rmyers
Does Steve have a car?
Rmyers's Avatar
re-read post, please delete
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2006, 11:15 PM   #8
ebxr8240
Performance moderator
ebxr8240's Avatar
Did you fit new leads ???
Daily driver GTE FG..
Old 11-02-2006, 11:50 PM   #9
hako
hako's Avatar
Park and neutral should be identical.
Old 11-02-2006, 11:53 PM   #10
svo347
AFF's 1st DM.......
svo347's Avatar
Do those use a tps to sense throttle postions.. Im thinking one may be out.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 11-02-2006, 11:59 PM   #11
Nath
NA Series II
Nath's Avatar
Yeah i fitted anew set of bosch leads today to replace the ICE ones i had in it didnt make a difference though!Whats a tps?throttle positioning system?
