Old 13-02-2006, 01:42 AM   #1
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
Default Engine temps with intercooler blocking radiator
Hi,
My cars coolant temp is reaching the top of the R in Normal since the intercoolers been on... I can understand that it will run a little hotter, but is thee any danger in this???
Just wondering if this is normal?? And should i worry about getting the thermos on constantly? Or something else?
THe cooler basically blocks all air flow 770x300x76 so its understandable... But i get a bit giddy seeing it up there on the temp gauge.
Cheers.
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 08:24 AM   #2
KLR250
KLR250's Avatar
Do you run aircon? I pulled mine off because of this. My engine temps never changed with the cooler in front of the rad and its a pretty big thing, but mine isnt OHC either, you should still have resnable airflow through the core, its it bar and plate or tube and fin?
KLR250 MKII, coming soon.............
KLR250 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 11:55 AM   #3
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
dont use aircon lately, especially when i see the temp going up. I would have thought there would be better airflow.
Cars:
- XY GT Replica
- XB Coupe Project
Old 13-02-2006, 12:26 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
i know a friend of mine was having similar problems.
had to get the radiator cleaned out to try and improve the situation.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 13-02-2006, 07:30 PM   #5
blwneb
come join me
blwneb's Avatar
does it rise at idle, it will, it should drop when moving as revs are up, and water flowing better, you could try and fit a elec water pump, ewp110.
ID RATHER BE BLOWN
blwneb is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 08:13 PM   #6
NZ
NZ's Avatar
What does it look like from the side in terms of places the air could bypass the radiator? Air will take the natural path of least resitance. The other thing you could measure is the air temp before and after the cooler to see what the radiator actually has to cool with.
Old 13-02-2006, 08:15 PM   #7
svo347
AFF's 1st DM.......
svo347's Avatar
Maybe so but if theres not enough air flow thru the system you,d be pumping hot coolant around
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 13-02-2006, 08:28 PM   #8
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
sure its not just running hotter because u put the intercooler and wound up the boost abit?
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 08:31 PM   #9
EFFalcon
Last warning
EFFalcon's Avatar
the intercooler *is* the reason.
he's askin if its normal for it to run that hot.
theres simply not that much of an intake on EF front bars.
Old 13-02-2006, 09:30 PM   #10
XR Martin
XR Martin's Avatar
Try a 3 core radiator, and mod the thermofans to come on earlier.
2004 BA wagon RTV project.
Old 14-02-2006, 10:43 AM   #11
LTDHO
The one and only
LTDHO's Avatar
I wouldn't be to concerned.
At the same boost without cooler, does it run as hot?
Tuned by CVE Performance
Old 20-02-2006, 04:13 AM   #12
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
oh its definately got to do with blocked airflow, im just wondering what people have done to cool it a little, just to be on the safer side.
When cruising on highway its ok, but it definately hotter at slower speeds/traffic...
My radiator just crapped itself which i could probably blame this on too lol oh well...
Will look at a bigger radiator. Any different models with better radiators which will bolt in?
Cheers.
Cars:
- XY GT Replica
- XB Coupe Project
