Old 15-03-2006, 09:44 PM   #1
old fordnut
too many fords
old fordnut's Avatar
Default Difference in engines
Whats the difference between the 185kw engine in series one AU and the 200kw in AU2?
old fordnut is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2006, 07:05 PM   #2
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
you must be talking about the XR's??? but i'd say the difference is 15KW
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2006, 07:13 PM   #3
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Like most 'series' upgrades of the same model, normally comes down to exhaust / ECU calibration to get a hike in power.
They are I believe the same crate Windsor motor. Not sure what they did to get 220 KW though from the same.
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2006, 07:15 PM   #4
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Not sure on the 185Kw Engine V 200Kw i asked a similar question in the Tickford Forum a while ago do a search in there and you will fnd your answer
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2006, 07:35 PM   #5
sbcb
BA Xr8
sbcb's Avatar
Heads,cam, air intake, roller rockers. 200kw motors are the first of the hand built engines - have the Tickford engineers name on a small plate on the rocker cover.
http://www.aufalcon.com/Articles/handbuilt.htm
sbcb is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2006, 09:52 PM   #6
old fordnut
too many fords
StandardAu:
No S$#@ Genius
Thanks FPV8U, Ill check that thread
Old 16-03-2006, 09:53 PM   #7
old fordnut
too many fords
StandardAu:
No S$#@ Genius
