Old 04-06-2006, 12:45 AM   #1
JouMa
Default After Market HeadUnit Installation
Hey
I just got a new Headunit
I Currently have the Premuim Sound System. I took it all out..then looked at the brackets and mounts..there is no way that it i can make it fit. How have people over come this and what has been done to close the bottom hole???
its an EFII Ghia
JouMa is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 09:39 AM   #2
Ultimate
Pimp Daddy Pimp Pimp
Ultimate's Avatar
Location: Queensland Events Assistant Co-Ordinator. Fiery's Little Helper
Ok mate can you provide us with the type of headunit you bought. The ef/el i seen never had a issue with this before.
Jeff
Got a Qld, Contact Us
PM ULTIMATE
PM FIERY (The Guru)
AFF Merchandise
Excellent Purchases With: AFF Team, Rooster, Russ
Ultimate is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 11:39 AM   #3
John_LS1
you can buy a single din surround out of a GLi or something that way the gap will now have a pocket there instead.
use you old stereo brackets on the new headunit. should go in alright then. if its a well know brand unit generally thehave multiple mounting holes on the side of the deck.
Old 04-06-2006, 11:54 AM   #4
EFDream
XRR83D
EFDream's Avatar
Yeah I used a single din cover to close off the hole and was able to use the brackets off the double din unit to mount the aftermarket stereo. The wiring was the worst part for me!
2003 BA XR8 Falcon - Lightning Strike
Mods: 18" GT's (Aftermarket), BF GT front end(FibreSports), Tint, Premo Sound, Leather, CAI, DBA slotted,
2007 Suzuki Swift - Pearl Red
Povo Pack
EFDream is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 12:48 PM   #5
EFFalcon
Last warning
EFFalcon's Avatar
depending on the headunit we'd have to modify the stock brackets.
the black L brackets have sometimes needed to be flattened a little and new holes made, sometimes they've gone straight on.
seems to depend on the headunit.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 04-06-2006, 03:28 PM   #6
JouMa
the headunit is a JVC KD-LXH555
the old headunit bracket doesnt fit on it.no holes line up
Old 04-06-2006, 03:56 PM   #7
JUZXR8
Hmmmmm
JUZXR8's Avatar
drill new holes in the stock bracket to suit the headunit
mod that up!
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 03:59 PM   #8
crannersEL
crannersEL's Avatar
mod that up!
I didn't bother drilling new holes in my brackets so my headunit sits a little further back than it should be. If you use the stock brackets you can also use the stock rails.
I don't understand how the grey frame work that comes with the headunit fits because in the EL/Ef's there is no shelf to rest it onto.
In the end i didn't use it just settling on the headunit sitting a little further back into the dash.
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 06:56 PM   #9
EDXR6T
it's called modding ppl:P
if the bracket's dont fit. MAKE them fit!
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 07:03 PM   #10
EFDream
XRR83D
EFDream's Avatar
^^^^^^^What he said!^^^^^^
Povo Pack
