Old 08-06-2006, 11:49 AM   #1
EAman
Ea 1990 with ef head
EAman's Avatar
Location: recently relocated from gipsland to newcastle
Question how do i wire up this ea trip computer
So i bought a trip computer on ebay for a ea fairmont it has no wiring loom is there one behind the clock pannel in my car or do i need to actualy do some wireing and soldering????
EAman is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 11:56 AM   #2
crannersEL
crannersEL's Avatar
Ive got an EL and ive been told that the one behind the clock pannel is just for the clock, so im guessing its either find a loom in a wreck or its soldering and wiring time.
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 12:07 PM   #3
EAman
EAman's Avatar
wouldn't know someone on here who might have the information on wireing or loom???
Old 08-06-2006, 12:09 PM   #4
gthofan
Gunna girlie-man
gthofan's Avatar
hey, the wire connector behind the panel is just for the clock. You will need the connector from the wrecker for the trip computer. from the clock connector though, you can use the constant power, ignition power, and illumination, and ground, to tap into the trip computer wires. then there is the speed sensor, eec 4 connection and some others, which u will need too add. for more info, just check out www.fordmods.com
ive done this mod ages ago, takes about an hour to complete, well that was in the dark, so about .5 hours
http://www.fordmods.com/forums/documents.php?doc=46
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 12:12 PM   #5
EAman
EAman's Avatar
so if i get this plug from the wreckers then i still have to do some wireing or not???
Old 08-06-2006, 12:13 PM   #6
gthofan
Gunna girlie-man
gthofan's Avatar
yep, just check out the guide on fordmods from the link in my previous post. very straight forward, and a good mod
you only need the connector and about 3 inches of the wires behind it, itll be plenty of room to tap into existing wires, and make new connections
Old 08-06-2006, 01:09 PM   #7
EAman
EAman's Avatar
sweet will keep u posted
