Old 09-06-2006, 08:13 PM   #1
syktlr
stktlr
syktlr's Avatar
Default mpfi pump on cfi?
can i run a mpfi pump on my ea running an ef motor with cfi untill next month when i put mpfi onto it as mine is playing up.what ecu will i need to run the 3spd untill i get a manual. thanks
syktlr is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2006, 09:24 PM   #2
JUZXR8
Hmmmmm
JUZXR8's Avatar
nope, the mpfi pump will pump at 250 while the cfi is only about a 100 form memory....dont think u will be able to run a 3spd with an ef motor
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2006, 09:34 PM   #3
syktlr
stktlr
syktlr's Avatar
i already do run a 3spd
Old 09-06-2006, 09:43 PM   #4
JUZXR8
Hmmmmm
JUZXR8's Avatar
yeah on cfi tho? i dont think there is a 3spd mdfi ecu
why would you run an ef motor on cfi anyway?
Old 09-06-2006, 09:45 PM   #5
syktlr
stktlr
syktlr's Avatar
thats how i got it and i wasnt complaining for 500 with a new head.is there no 3spd mpfi's
Old 09-06-2006, 09:47 PM   #6
syktlr
stktlr
syktlr's Avatar
when i do the mpfi convert it might be best to do trans aswell.but i thought to save money for now then do trans later
Old 10-06-2006, 01:22 AM   #7
frost
frost's Avatar
yes you are
and there are so 3spd MPFI my EA was orginally a 3spd MPFI, it even had an LSD, its a GHIA.
I found something out and proved it worked, MPFI and CFI fuel pumps are the same execpt one thing, the outlet, u know the differnce, the MPFI is a fully opened end, the CFI one is got like a 4 star screw driver head. So all I did to get some fuel happening, is punched it out with a screw driver and connected, worked like a dream.
Your better off MPFIng it and dropping a T5 in to boot, You need to change the ECU but theres no major differnce bettwen the MPFI 5spd and 3-4spd auto ECUs
frost is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2006, 06:06 PM   #8
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
no mate i wouldn't dare put a cfi pump in a mpfi, bad bad idea the cfi pump only run at 75-100cc per min and the mpfi pumps will go to 300cc per minute, you will lean the engine out at high revs and under load, stick with what is ment to be.
The other way would be ok because the xces fuel would just run back to the tank via the return line.
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2006, 06:08 PM   #9
LUXO_8
windsor user
there is no specific ecu for a 3 speed, they are not an electronic box.......
you just use an early mpi ecu (S , Ghia) etc......
