Old 20-06-2006, 10:41 AM   #1
sednwol
sednwol's Avatar
Default XR8 fuel question
As you know I have just got my XR8 S3 and through out its previous life it ran on Caltex Vortex. I had my first fill up and put in Shell PULP '95, and now the cars idle (in drive) is a little rough. I don't believe the fuel is "bad". Could this idle isue be due to the change of fuel? I have also heard that the ECU (or whatever) will "dial in" the new mix and adjust, is this true?
Also,what fuel do you XR8 owners use?
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 11:49 AM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
I own a xr6 so bit of different kettle of fish, but still , it could be just the 2 types of fuel mixed ( the old and the new ) creating a wierd effect maybe ??. As far as the ecu 'learning' the octane level of the fuel , im not sure it does - I think it's possible to get your car tuned to run better on higher octane fuels etc etc , but the ecu just works out the fuel/air ratio according to the engine/coolent temp (during warmup) and the o2 exhaust sensor when warm & running i think. ?
Whatever the case , gone are the good old days of the air/fuel mixture screw on the side of a carby ! ..lol
Good question though , as i have noticed if i run on normal unleaded my car is a slug and idles like rubbish ( i get real bad economy too ) , 95 octane aint bad in my car , seems to idle smoother and the economy is a bit better and performance too , but in the end i stick to the 98 as i seem to get the best bang for buck , even though it cost more a tank seems to last me way longer , way better economy than the other 2 fuels , very noticible on how far down i have to put my foot into it too when using different fuels to obtain the same sorta torque/power. Allways runs like a gem on the 98 too ;) .
:eclipsee_
Old 20-06-2006, 01:40 PM   #3
sednwol
sednwol's Avatar
Hmmm, Vortex is rated 95, I thought it was 98. I thought that was my answer. Well if 98 will get me further per tank then price is really realitive and performance and a "cleaner" engine is the result.
Old 20-06-2006, 01:46 PM   #4
XR6-VCT-2000
Fantastic Plastic
Don't quote me on everything i said above , thats just in my case , with my car / you might find it the same for yours too, maybe ?
.. And as for the other stuff on the ecu im not 100% sure about ! , i thought i'de at least just start this thread off , as there was sooo many looksys but no replys. ;)
:eclipsee_
Old 20-06-2006, 01:49 PM   #5
sednwol
sednwol's Avatar
Hopefully some of the guys with XR8's will give me some feedack re the fuel they use etc and whether the ECU (or whatever) will "dial in" the new mix and adjust. Thanks XR6-VCT-2000.
Old 20-06-2006, 01:51 PM   #6
XR6-VCT-2000
Fantastic Plastic
;) , np ... i'm sure i'll probably get backlash over what i said ..lol , thats cool though , as i'de like to know 100% for sure too . cheers
:eclipsee_
Old 20-06-2006, 01:59 PM   #7
SIKXR8220
SIKXR8220's Avatar
Hey mate i always use shell pulp 95 only because its the closest one to me and my car does idle a touch rough, i am not saying its the fuel but from what you have said it could be, i might whack a tank of ultimate in and see what happens. As for the ecu question i wouldnt have a clue, soory.
My Ride
2005 BA MKII F6 Typhoon- details soon.
SIKXR8220 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 02:16 PM   #8
sednwol
sednwol's Avatar
Definitly worth a try. My car (Series 3) didn't miss a beat on Vortex (95 ron) by boy it doesn't like the shell 95.
Old 20-06-2006, 03:05 PM   #9
SIKXR8220
SIKXR8220's Avatar
Shell is claiming that their 95 is the most economic of the 95's
My Ride
Old 20-06-2006, 03:09 PM   #10
XR6-VCT-2000
Fantastic Plastic
lol , for the few cents extra , but for the piece of mind and no problems and good performance, i'll stick to my 98 hi octane fuel tyvm ..lol
:eclipsee_
Old 20-06-2006, 03:34 PM   #11
sednwol
sednwol's Avatar
Yep, Iam going to try it!
Old 20-06-2006, 03:36 PM   #12
FTE217
T3/Sprint8
FTE217's Avatar
I have never run 95 in my S3XR8, 98 is the only go for better everything,far out weighs the savings pumping 95 in the tank.
My T3 will be the same nothing but 98 or 100.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 03:48 PM   #13
sednwol
sednwol's Avatar
Yep Iam sold! No doubt this will fix the rough idle. :hihi:
Old 20-06-2006, 05:16 PM   #14
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I run BP Ultimate in mine, I used to run Opticrap vbut found it to inconsistant, I have never had a problem with Ultimate and mine idle's nicely.
Old 20-06-2006, 05:20 PM   #15
HLC
Audi S3
91 RON woolworths petrol for me :hihi: cant afford anything better :
Old 20-06-2006, 05:23 PM   #16
sednwol
sednwol's Avatar
I run BP Ultimate in mine... I have never had a problem with Ultimate and mine idle's nicely.
I get discount tickets for the local BP, I'll try the ultimate
Old 20-06-2006, 06:00 PM   #17
galaxy xr8
Giddy up.
galaxy xr8's Avatar
How do you get that, that would come in handy.
Old 20-06-2006, 06:14 PM   #18
sednwol
sednwol's Avatar
Shopping at Ritchies supermarkets. If there's one in Bendigo they probably do a deal with the local BP.
Old 20-06-2006, 06:24 PM   #19
ReVd_uP
ReVd_uP's Avatar
AU XR8 at close to 100 000 kms? id be looking into leads for the idle concern, or you could wait till it starts missfiring, wouldnt hurt to change plugs either, in answer to you other Q, i run my xr8 on 98, although mines been edited
ReVd_uP is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 06:29 PM   #20
xd5.8l
xd5.8l's Avatar
They all idle like crap but all is forgiven when the right foot hits the firewall :
xd5.8l is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2006, 06:40 PM   #21
sednwol
sednwol's Avatar
It was idling beautifully until I put the Shell '95 in, sure leads will be soon but that's not the issue at present.
Old 20-06-2006, 06:42 PM   #22
xd5.8l
xd5.8l's Avatar
start her up now sednwol and watch the firworks. Close the bonnet on yourself so its extra dark if anyone asks you what your doing tell them to f$%k off.
Old 20-06-2006, 06:44 PM   #23
sednwol
sednwol's Avatar
: Great advise mate!
Old 20-06-2006, 06:45 PM   #24
8pAc
RDP #181
8pAc's Avatar
My series 3 xr8 like optimax better then ultimate, my older 6 liked it the other way round.
Originally Posted by MRJUCY
Camrys like most Toyotas have always been ugly, poorly equiped & brain crushingly dull but that's what a lot of people look for in a car unfortunately. I like my fridge, it keeps my beer cold other people like them so much they want to drive them it seems.
8pAc is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 08:00 AM   #25
fordAU
Correct me if I am wrong but as far as I know the 200/220's are tuned for 95 octane.
On a 220 I have found no difference between 95 or 98, if anything this particular vehicle seems to like Vortex 95 the best out of all them for economy, performance wise I don't think there is any difference between them.
fordAU is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 09:08 AM   #26
sednwol
sednwol's Avatar
Don't you get better economy using the '98 ron? Or is that an urban myth?
Old 21-06-2006, 09:32 AM   #27
XR6-VCT-2000
Fantastic Plastic
Whatever works best for you and your car , or whatever you've had it specifically tuned to run on. ;) .
:eclipsee_
Old 21-06-2006, 01:03 PM   #28
fordAU
Not really sure, many reckon you do but I can't really say.
I drive pretty sedately being an old codger, should take it out and give it a bootfull, give it a canning, on the track offcourse. :voldar02:
Old 21-06-2006, 05:45 PM   #29
SLY 68U
Ive got an AUII XR8 220. I've always run vortex 95 and its never missed a beat.
Ran vortex 95 at Eastern Creek and ran a 14.607. Only mod is SS CAI
SLY 68U is offline   Reply With Quote Multi-Quote with this Post
