Old 15-03-2005, 09:04 PM   #1
frtmatt83
ANOTHER FORD DRIVER
Question mechanic
i took the car down to the local mechanic for a gear box service. He went over the car and found a few problems i don't where to start because money is tight so i getting one thing at a time dowe. Could u guys tell me in order which u think are the important ones:
*windscreen washers need reconnecting
*gas leaking from air con compressor
*rear swaybar rubbers
*front swaybar rubbers
*rear upper and lower trailing arm bushes
*both engine mounts
*gearbox mount
*tail pipe starting to rust
*a/c belt
*pwer steering belt
any help will do
thanks
matt :tool:
frtmatt83 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 09:17 PM   #2
FRDXR6
FRDXR6's Avatar
Windscreen washers you could probably do yourself and depending whether or not you use aircon much that could be pushed down the list. So probably do the mounts and power steering belt first then maybe bushes.....but im not a mechanic and don't know much so maybe wait for someone else to reply :
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 09:26 PM   #3
Yagz
engine/gearbox mounts, power steering belt and rubbers and bushes.
The rest is trivial bullshit.
Yagz is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 09:31 PM   #4
INJECTED_250
Custom user title
INJECTED_250's Avatar
well the ac gas.. ya better of waiting for it to leak out becasue u will be up for a re gas to get it fixed any hows.. all the other shit sounds pretty normal
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 10:00 PM   #5
EL_futuraistic
EL_futuraistic's Avatar
Default yeah, some is trivial.
yeah, you could do the washer jets urself, then i would start with the mounts, then the belts (both belts... change 1 change all), followed by the bushes/rubbers. THEN when you have sufficient money tackle the aircon, because you will probably need a new or reco'd compressor aswell as a re-gas and new seals.
EL_futuraistic is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 10:22 PM   #6
INJECTED_250
Custom user title
barr bugger the new aircon compressor.. thats just scarry... go second hand from a low k car.....
Old 16-03-2005, 07:19 AM   #7
bindi
Redhead extraordinaire...
bindi's Avatar
Yeah I agree, don't worry bout the air co just yet, open your windows! I would actually get a 2nd opinion just to make sure he's not taking you for a ride...
The windscreen washer reconnection is easy, if I can do it, YOU can Get mounts, bushes and belts done. If you go to the right place it's not too expensive - if you get it all done at once it will save you a bit of money. If you can't afford that (like me atm), then group belts together, bushes together and mounts together and get it done one group at a time.
Tailpipe? Later.
Bindi
88 EA- his car
88 Rolla - MY car
Originally Posted by big_waity
Oh, and another surefire symptom will be the Falcon badge at the back.
bindi is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2005, 10:51 AM   #8
LTDHO
The one and only
LTDHO's Avatar
OK, by now you should have done the washer jets as they are sooo easy.
Next bushes. Why? Because they effect handling and braking and are safety related and make them priority.
Whilst driving causiouly save for the mounts. Also locate leak for AC. It may only need a tighten!
Assuming the belts haven't fallen apart by now, replace these. All the time your exhause is still working.
Now save for a sports exhaust. Why? Easy, whynot. They are not that expensive and you will notice the difference.
Tuned by CVE Performance
Old 16-03-2005, 05:09 PM   #9
bindi
bindi's Avatar
Ok how much is "not that expensive"? I am curious as it is something I would like to do to the EA when I inherit it.
Bindi
88 EA- his car
88 Rolla - MY car
Old 16-03-2005, 05:12 PM   #10
EFFalcon
Last warning
EFFalcon's Avatar
sports exhaust = $250-$300 + fitting
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 16-03-2005, 07:10 PM   #11
bindi
bindi's Avatar
Hey that's better than I thought, although fitting could be really expensive for all I know lol
It's like paint. I always assumed it would be quite cheap to paint a car, then I find out it's a fair few grand and some are up in the tens of thousands... and I almost fell over!
Ta John for the enlightenment _2:
Bindi
88 EA- his car
88 Rolla - MY car
Old 16-03-2005, 07:25 PM   #12
EFFalcon
Last warning
EFFalcon's Avatar
exhaust is easy to fit.. shouldn't cost too much for fitment.
Old 16-03-2005, 09:06 PM   #13
EB6
apprentice grease monkey
EB6's Avatar
if the belt r bad like theyll break do them first, its cheap anywho,
next do ya engine/gear box mounts so ya car isnt gonna get shaken to pieces and have the engine smashed around everytime it is rev'd. then go ya bushes if ya take cornering easy ya should be fine unless there good and dead, ya'll hear a know when tehre dead if there only worn ya wont hear anything just th car will roll a bit more. if ya were able to live with them for a while ya would prob find labour to be cheaper to get it all done at once instead of bits and pieces here and there.
EB6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2005, 09:20 PM   #14
DanXR6T
Eat more peanuts....
DanXR6T's Avatar
The windscreen washers are a trivial thing to pay someone to do but don't forget about them.. its makes your car unroadworthy... and if you get pulled up by a picky cop..
Swaybar bushes are easy enough to do yourself.. all you need is a few spanners and a jack.
'04 Falcon XR6T Ute, Envi, K&N filter, F6 Intake, Twin 2.5" exhaust...
Formerly owned:
'99 AU Falcon Ute
'88 EA Falcon GL
DanXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 12:35 AM   #15
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
err sportsexaust fiited from an exaust shop should be no more than $300 FITTED
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2005, 11:31 AM   #16
XRated
Shoot.
XRated's Avatar
Absolutely. I bargained my way down to $180!! : And that's a quality set up that most of the guys on here are basically running. My mate just got a Redback 2.5" mandrel bent, one muffler and resonator for $250 fitted. Just go in there knowing what you want.
20V Turbo
Old 17-03-2005, 10:42 PM   #17
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
engine mounts you can do yourself too, with a few spanners and a jack (And a block of wood... and a ramp or similar)
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2005, 07:56 PM   #18
frtmatt83
ANOTHER FORD DRIVER
thanks for the help as i know nothing about car i will get the mechanic to do it, At least i know the order to do it in
matt
Old 20-03-2005, 08:57 PM   #19
SileNceR
SileNceR's Avatar
get an ellerys or gregories manual and you should be able to do a lot of it yourself, you'll never learn if you never try, and you should save yourself just a little cash ;)
211RWKW EA
