Old 18-03-2005, 02:53 PM   #1
biased99
Occasional V8 user...
biased99's Avatar
Default Indicator R&R - EB.
OK, I'm going to remove the stock front blinkers from the Fairmont and install some clears...Having a brief look last night suggests that the headlights also have to be removed to do this. Is this correct? Are there any particular gotchas in doing this R & R (such as hidden screws/bolts tabs etc)?
Sorry if it's been canvassed before (probably ad nauseum, knowing my luck!)...If it has, a link to a howto or similar thread would be handy.
biased99 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2005, 03:10 PM   #2
dansedgli
dansedgli's Avatar
yeah take the whole headlight out. Should be 4 or so 8 mm plugs holding the lot in plus the 2 plugs for the indicator and headlight. Take it out and 3 phillips head scrrews hold the indicator onto the headlight.
2 bolts above the headlight into the chassis, 1 behind holding it down in front of battery and airbox and also 1 on the inside near the side of the radiator. The last is the hardest to get to but still fairly simple.
Hope that helps.
Dan
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2005, 03:38 PM   #3
JADED6
V8 Ghia & BF2 XR6 + Wagon
JADED6's Avatar
The side bolts are the bitch.
4 bolts per light.
Just remove a total of 8 small bolts, (dont forget to unplug the lights & indicator)
Then pull the light out, unscrew amber indicator, replace with clear.
Sounds easy.
(for me it involves removing the front bar.. grrrrr)
Windsor now harmonically balanced for EARTHQUAKE free driving!:
JADED6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2005, 08:44 PM   #4
biased99
biased99's Avatar
Thanks very much guys...Your advice worked a treat!
(Easiest mod I've done to a car yet!)
Again, thanks!
