Old 05-01-2005, 02:34 PM   #1
yo_stock
Exclamation One chat to Brendon Mock
Hi guys, all the ppl runing MPFI, from CPFI, who has changed the dizzy? They don't run propperly, like might run fine, jus without al the possible power... what you guys think?
yo_stock is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2005, 05:50 PM   #2
Kenaz
Kenaz's Avatar
I don't understand a thing you just typed. And what does Brendan Mock have to do with this?
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2005, 06:25 PM   #3
Brent-EA Ghia
Brent-EA Ghia's Avatar
Cool
I was thinking the same?? maybe its a code!
Brent-EA Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2005, 06:32 PM   #4
JADED6
V8 Ghia & BF2 XR6 + Wagon
JADED6's Avatar
CODE? LOL
Im one to fill in the blanks so here goes..
He had a chat to b-mock & He said anyone that does the cfi-mpfi should change the dizzy or their cars wont run properly.
Now.. can I add that the thread should have been a lot more informative yo stock.. Ie; what, if any were his sugested changes to the dizzy...
JADED6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2005, 06:49 PM   #5
spope
spope's Avatar
That's a very confusing question, but I think the answer is no.
I changed to an MPFI dizzy when I did my conversion, but it's mounted in the CFI position. There are many who haven't changed, and had no problems.
The only difference is that the mpfi has a little cut out in the pip rotor for the pip signal so the ecu can tell when the engine is at tdc. What that actually does, I'm not sure.
Your dizzy will affect your power if the timing isn't set properly, but that's about it...
spope is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2005, 06:52 PM   #6
Brent-EA Ghia
Yeah thats the only difference ive come accross, but to me it doesnt make sense why they made them different between the two??
Brent.
Old 05-01-2005, 06:55 PM   #7
EASPRINT
FPV GT-P 335!
EASPRINT's Avatar
my old wagon wouldn't run 100% with multi point until i changed the dizzy over. That's why Brendan's probably saying that that. Cause we realised that when we changed mine over.
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E
Tuned by Michael J's & Son.
EASPRINT is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2005, 07:22 PM   #8
stockstandard
So glad I am not the only one.
Could this have been that the cfi dissy was faulty (got knocked around a bit etc). I thought they were all (ea-ed + el) pretty much interchangable.
Originally Posted by casper
Old 05-01-2005, 09:19 PM   #9
NZ
NZ's Avatar
What that cut out does is fires the correct group of injectors at the right time. CFI it doesnt matter, the injectrs are common to all cylinders. MPI it does matter
Old 05-01-2005, 09:36 PM   #10
Brent-EA Ghia
Ahh it makes perfect sense now! thanks EB MkII.
Brent.
Old 05-01-2005, 11:02 PM   #11
Smoked
Burnin Rubber
Smoked's Avatar
If u set the tune with the CFI dizzy correctly, your car should be fine.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2005, 11:15 PM   #12
rodderz
rodderz's Avatar
lol...Smoked that posty pic is a pearler!!
Wonder if he had to put some oil under there to get the smoke lol
rodderz is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2005, 12:16 AM   #13
Bobman
Regulator
Bobman's Avatar
lol yeah too true
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2005, 08:53 AM   #14
AUII_Forte
AUII_Forte's Avatar
I have done the MPFI conversion without changing the dizzy and the car is running like a dog! Been like that for a few months now lol. The timing mark is sitting WAY advanced but and the car pings alot, but if I back it off to 10deg in self-test mode, it won't run. It's also backfiring a lot and has a huge flat spot. The timing is just sitting static on the one mark, I've tried 2 different ECU's, triple checked the wiring, changed injectors, changed various sensors etc so all I can put it down to is the CFI dizzy, just have to get off my *** and find an MPFI one to try.
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2005, 09:47 AM   #15
NZ
NZ's Avatar
AUII Forte: If you take out your dizzy you can actually modify it to become an MPI dizzy. All you need to do is punch out the pin on the drive cog, slide the whole shaft and cutter bar out and then file down the correct vane.I did have the measurments from when I did mine but since lost them hehe.
Old 06-01-2005, 11:28 AM   #16
AUII_Forte
AUII_Forte's Avatar
I was thinking about doing that, but I I've decided to wait and just by a brand spankers new one. Assuming the dizzy is the original, it has 320,000k's on it, so I though that it's probably not even worth stuffing round with.
2.5" Exhaust
High Flow Cat
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
