just wondering where exactly can you get high ratio diff's that fit onto the e-series, as im interseted for something around the 3.7 ratio. Where exactly is a good place to start looking, and what modifications would i be looking at to fit it in my car?
Thanks |
![]() Join Date: Dec 2004
3.7s can be had from R31 skylines. I think it may have been the Series 1 model.
3.9s can be had in S2-S3 R31s, and 4.11s can be had from Pinnys ;) Beware the skyline diffs though, test one before buying! I bought one untested and (no fault of the seller) it was stuffed. |
Whoa, this is heavy!
All r31 skyline manuals were 3.7, all r31 skyline autos were 3.889, and most whine from the factory.
Liquid Silver 2002 AU III Fairmont wagon Le Mans Red 1990 SA Capri Turbo
#4 | |||
V8 Ute V8 Boat
get a skyline one just get a lsd
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
ah ok thanks, what issue's are there with fiiting them onto, say me eb? Do the r31 skyline diff's have LSD? How much does it cost for one second hand roughly?.
Mine was $150. The skyline 3.9 that is, not my 4.11s. I'm not too sure on cost differences between SS and LSD Skyline diffs, but if you could source a cheap Ford LSD the skyline gears will fit in fine with this. You swap the centres over rather than the entire diff.
#8 | |||
Runnin C3H8 & C4H10
Production Editor- Street Fords, Xtreme Fords, Aussie Brutes and Custom Utes Magazines sam@streetfords.com Phone: (02) 9741 3838 (direct line) |
$150? is that all!. Thats a pretty cheap and easy mod to do then, just one more question. Did the R31 skylines have ABS or not, as im after a non ABS diff. If the R31 skylines do have ABS, would it be possible to mount the connections of the ABS diff into a non ABS car?
cheers |
Oops, I slipped....
As said above, you can't fit an R31 diff in an E-Series, you just replace the diff centre.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
