Old 30-11-2006, 04:51 PM   #1
EL8TED
It all counts
Default shock towers
what kind of price would i be looking at for replacing the shock towers ? i think thats what theyre called .. ?
im fairly sure they are worn.
NWOLB 8 built by Autotech Engineering tuned by KPM
EL8TED is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2006, 05:07 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
I assume you mean the front struts, what car, the EL XR8?
Old 01-12-2006, 04:13 PM   #3
EL8TED
It all counts
yeah an EL xr8, nah im referring to the actual top rubber bits .. or something i read about some dude that replaced them on his AU's. cos up the top of my shock tower i have a real annoying groinching noise and ford told me it the part that the struts mount to or something.. not that i hold thier word as gospel. But theres nothing else that high up on the car in that region.
Old 01-12-2006, 04:18 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
ok, you have struts, now they have shock rubbers, and a top spring rubber mount. Thats about it.
So you actually want some new front shock mount rubbers, a bit tricky to replace without sping compressors too.
Old 01-12-2006, 04:34 PM   #5
honer
Back to N/A land
Or balljoints
I had the weird creeking sound from mine before I lowered it, once I replaced springs / struts etc I still had it.
Turned out to be balljoints in the end.
honer is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2006, 12:39 AM   #6
EL8TED
It all counts
what RRP on the rubbers ?
and also the ball joints if thats the case ? how can u chack or find out theyre stuffed ? what did it cost u honer ?
Pedders didnt pick up either of those in thier supposed safety check..
something about some bushes causing it .. but i know 100% its not them. i know they are worn, but they arnt the problem..
Old 04-12-2006, 11:37 AM   #7
Tiga_EL
Tiga_EL's Avatar
I had a similar problem thinking it was the rubber bit, turned out the clunking noise was a loose caliper.
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
