Old 13-05-2007, 11:37 PM   #1
partie
Default HID - AU reflector issues ??
Hi,
just curious to know if anyone with an AU that has fitted HID found any issues with it damaging their headlight reflectors ?
I want to be careful and avoid bubbling the chrome lence. I have fitted HID's to EF/EL and they dont have any issues.
Patrick
partie is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 11:46 PM   #2
LUXO_8
windsor user
i wouldnt fit a HID kit to an au headlight full stop, they're a reasonably glarey headlight to begin with, it'll only be exhasberated with a HID kit..
just so you know, fitting a HID kit is illegal.....and you will be defected for it.
IF you really want HID, do what ive done and do a propper retrofit, thats where you take all the HID parts out of an OEM Xenon headlight and retrofit it to your headlights.
ive been there/done that with a hid kit, and retrofitting OEM xenon parts just walks all over a kit....
please take a read of my custom headlight thread in my sig, you'll see where i went from standard lights, to custom lights, to xenon kit, and finally to a propper retrofit........
Old 13-05-2007, 11:59 PM   #3
Umineko
Karasu
Umineko's Avatar
Originally Posted by MADNC_8
i wouldnt fit a HID kit to an au headlight full stop, they're a reasonably glarey headlight to begin with, it'll only be exhasberated with a HID kit..........
Too right, you might as well tie a flag to the antenna that says all cops suck, AU's had glare issues just using the standard 55W bulbs
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 12:27 AM   #4
FGII-XR6
FGII-XR6's Avatar
just a side issue if you want to improve the glare and get better light fit alteza headlights they look GR8 and perform better
Old 14-05-2007, 12:57 AM   #5
Hords
Treasure your balls?
Hords's Avatar
Yep, I've got Phillips Blue Vision globes in mine, and although I find them a decent improvement over the standard globes I still get oncoming traffic flashing me several times a week.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 08:25 AM   #6
The Dok
The Dok's Avatar
They are about as good as you can get so far as improvement goes, try aiming them down just a little.
The standard (genuine Ford) AU headlight is leaps & bounds better than those nasty Taiwanese copies. Don't just take my word for it, do a search, they have been covered previously :
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 08:36 AM   #7
Mechan1k
Mechan1k's Avatar
I had those same headlights in my ute ... but the chrome suround ... when they were first out ... the light beam was atrocious ... and with a prpoer HID H4 conversion kit in ... the glare was even worse ... the beam pattern was all over the place with so many different dark spots in areas it wasn't funny.
And the beam from the HID had strays they shone up in the tres as well and all over the shop ... the wife hated it when i used to follow her (and she's in a Territory which is higher).
I sed to blind her on low beam ... and I had the beam adjusted all the way down.
Also the highbeam adjustment on those Altezzas were nasty as well .. one was in the trees ... the other was on the road n further than the low beam light.
I put mine in a 44 gallon drum and burnt them/melted them.
I got rid og the HID conversion kit as it wasn't suited to the vehicle or the headlight.
I am now runing projectors and halogen globes ... and the beam pattern from those are fantastic indeed ... no dark sports ... and much better peripheral vision off the side of the road ... also the eam distance is much futher as well due to how the projector works with the cut-off shield behind it. My beam stretches futher ... but still remains arouns the rear bumper height of all vehicles on the road ... even if they are 70-100 metres away.
You acn see the difference when driving along a concrete divide on most motorways how the beam works and also the distance as well ... especially when comparing to other vehicles.
The only way you could use HIDs is if you have a complete rerto-fit kit from a BMW/Merc/Audi ... etc including their own ballasts and projectors (special type HID projector) ... and even still ... not really ADR approved for your vehicle then ... but probably the safest way of utilising HIDs in your vehicle.
f you can try and use one that has the gyroscopic height adjustment to auto level the beam of inclines to reduce glare as well.
Although if I was going to have HID headlights again ... it'd be on a vehice that came with them from factory and specifically designed by the car manufacturer .... no aftermarket jobies for me anymore.
I am back using halogen again and I am used to it .. took a little while to wea back of HID as I was used to the brightness ... but happier now that I am not using them.
Old 14-05-2007, 08:38 AM   #8
Orbit
Resident Nyctophobic!!
Orbit's Avatar
HAHAHA thats the funniest thing i've heard in a long time.
Orbits secret to life: Eat less, move more!
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 08:54 AM   #9
Mechan1k
Mechan1k's Avatar
Also those Altezza reflectors aren't the best and hate HIDs ... as I burnt holes in the back of them from the HID kit I had in them.
Old 14-05-2007, 01:01 PM   #10
FGII-XR6
FGII-XR6's Avatar
mine are the later ones I too had the chrome ones and they were as you described i put thes ones in a couple of months ago as i was assured they had sorted them and once I had adjusted them ( not an easy job I admit they are awesome) thats the second time someone here has used the same offensive reply when they haven't known what they were talking about so i suggest if you don't have something polite and constructive to say then say nothing after all to quote Abraham Lincoln it is "Better to remain silent and be thought a fool than to speak out and remove all doubt."
Old 14-05-2007, 07:07 PM   #11
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
I've got the blue xenon bulbs, and they are flippin' bright on low beam. Just have the factory high beam bulbs fitted. They seem to do an awesome job anyway... no issues so far with any of the crome-ing, etc...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 07:14 PM   #12
HLC
Audi S3
get alteza headlights they perform better
lol no they dont.
Old 14-05-2007, 07:32 PM   #13
LUXO_8
windsor user
the ONLY difference between the earlier and later ones is the later ones have the black shroud, they're still the EXACT same light and reflector..
they're dodgy, made of sub standard materials, etc.....
ive thrown out a few pairs already, which have melted both on the lenses and where the globes fit to the reflector..., thats with STANDARD WATTAGE GLOBES
they're bad news...sorry, but not a fan
Old 14-05-2007, 07:40 PM   #14
FGII-XR6
FGII-XR6's Avatar
these aren't the dodgy ebay ones i got these ones from a reputable body panel wholesaler and the give good light don't leak or melt i know there are crappy ones out there and i should have been clear on the different quality available
Old 14-05-2007, 07:48 PM   #15
b2tf
not here much anymore
b2tf's Avatar
I've seen a Philips HID Xenon Kit fitted to a BA Falcon, was their reps car and the results were impressive. But by his own admission it was illegal for use on the road and it's not something you could drive round with forever. And at over $1k for the kit, it's a lot of money to spend to have something you technically can't even use.
I have Philips GT150 globes in mine and am going to try a set of Crystal Vision globes in high beams, they are 4300k which makes them illegal but high beam is not something you use when anybody else is around anyway so they should be ok.
Personally I'd just try some better globes if you want a bit of an ugrade, and leave the altezzas to the ricers, they are hideous.
2024 F150 XLT
Old 14-05-2007, 07:56 PM   #16
Magna
Magna's Avatar
Originally Posted by partie
Hi,
Patrick
i know ur asking about AUs, but I did a ebay HID retrofit on a mitsu 380, and i noticed after a week there was a really faint dulling of the reflector, and they got really hot. so i took them out and am back to normal globes.
the AUs like the 380s have really big relectors and arnt really suited for a HID conversion. they throw out a LOT of light but even adjusted to the lowest setting i was lighting up street signs ks down the road :(
Magna is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2007, 08:04 PM   #17
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
I guess ignorance must be bliss cos I've got just the factory headlights with Phillips +50s and they are excellent. They are very noticeably brighter than 99% of everything else I see and on low beam there is a definite cut off line of light that I adjust to just below boot height at about 4 car lengths and there is no glare and I never get flashed by oncoming traffic. On high beam there is good penetration to about 300m and plenty of peripheral light for 90% of what the car does, especially in town. When I travel at night I bolt on a set of Lightforce 240s' with one spot and one combo and that gives out more than enough light for me.
Bushbasher
MINE- AUII Forte
Old 14-05-2007, 08:50 PM   #18
chief
FTF Club Moderator
chief's Avatar
I have the same projector headlights as Mechan1k' made by The Dok. I currently use Narva Plus 50 H1 globes. The best globes I have used by far, plus having the projectors make the light beam even better.
Albert Einstein:
Fords in the Park 2010
