Hi there i have only just started posting on here, i have a ef xr8 170kw, i've put a herrods exhuast on it, i ant it running up near 200kw at the engine
Things i need to no: What are these things and what advantage do they have by putting them in my car ? CAM? Pacemaker? Pod in the Box? Extractors? chip and where can i get one from? Thanks guys ![]() |
Explorer inlet manifolds, 65mm TB and GT40P heads will see 200 at the flywheel easy.
ThUmPeR
hey and welcome!
well the only thing on that list that i know anything about is the POD lol. i have a POD filter on my ED but i havent got it in a box, ive just got it exposed. mines therre mainly for looks and sound, but there ment to give you: better throttle response better fuel econamy better induction sound. cheers troy
1994 ED Falcon ICE: 7" DVD BIG MTX sterio OTHER: 2.5" exuast, Pacemaker extractors K&N Flat pannel 20" Gianna wheels Dropped on Pedders BA Bonnet bulge clear indicators all round Full EL Ghia interior |
Remebering though i am only 18 and i dont want anything ilegal 200RWK? wouldn;t that make it around 270KW at engine ? Well if u can give me a general price on those bits that owuld be awesome thanks mate
Naw, 200 at the flywheel, as in engine.
Should be able to get heads, manifolds and TB for $1000 if you look hard enough. Might end up cheaper to get an AU engine and sell what you don't need. Fitting will cost a bit unless you do it yourself. |
ThUmPeR
cheers mate thanks for that. only took my half an hours work.
im not sure about the K&N in a box, but my one was just a $25 pod from autobarn. hope that helps.
Does Steve have a car?
I believe the p-plater power regulations only apply to the vehicles standard power to weight ratio. For example legally you can get an EA and have it running 700hp, whilst you wouldn;t be allowed to buy a BA turbs as the standard power to weight ratio would exceed the limit. Stupid i know, but it's a good little loophole for us
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
