Old 12-11-2006, 04:51 PM   #1
JUZXR8
Hmmmmm
JUZXR8's Avatar
Default EB V8 + Gas + Pod = ???
hey guys,
ive got a k+n pod and heatshield sitting here off my old EA which i want to put onto the EB, but because its on gas im not sire if it will run properly with this on, cos the guy i got it off had removed the snorkel from the airbox because it was gettin "too much" air when it was running on gas causeing it to miss a bit.
anyone know how itll end up? because i would really like to avoid damagin the engine.
thanks
Juz
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 04:54 PM   #2
gthofan
Gunna girlie-man
gthofan's Avatar
it will be fine, thats what the mixer does anyway, i have an i6 on lpg and an unshielded pod, all is good! the mixer will determine the amount of air that get in.
cheers
scott
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 05:06 PM   #3
mcflux
mcflux's Avatar
gas backfire + pod filter = hobo dose :P
Old 12-11-2006, 05:08 PM   #4
EFFalcon
Last warning
EFFalcon's Avatar
don't know about that?
mine never sounded anything like a dose, just a flash and a big bang.
i can prove it if u want :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 12-11-2006, 06:02 PM   #5
mcflux
mcflux's Avatar
Rymers probably wouldn't want you to prove it :P again
A backfire would never sound like a dose anyway, but I have a vivid imagination and am very bored this arvo.
Old 12-11-2006, 07:04 PM   #6
JUZXR8
Hmmmmm
JUZXR8's Avatar
if it does backfire would it do any damage?
Old 12-11-2006, 08:35 PM   #7
gthofan
Gunna girlie-man
gthofan's Avatar
gas cars backfire often, it would be no different if you had the standard airbox, although a backfire with the air box, blew mine to pieces, so the pod is a great idea!!!! the pod will let the smoke out quick
Old 13-11-2006, 01:49 AM   #8
hmc 'mont
ELMONTY
hmc 'mont's Avatar
the gas systems usually have a pipe that faces into the snorkel against air flow, so if the air pressure is too great the gas system compensates to keep the right pressure. i dunno what would happen if you used a pod without an airbox? because this system would have no use without the box.
97 EL Fairmont - Regency Red
hmc 'mont is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 09:42 AM   #9
Tiga_EL
Tiga_EL's Avatar
I had a pod on my car which is also LPG, but it started idling rough, so i took it off. Im pretty sure that K&N doesnt recommend using them with gas powered cars. It may still backfire depending on ur gas setup, but instead of the airbox flying off, id say it would be the pod filter lol.
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 04:31 PM   #10
needfordspeed
Yup it'll blow the pod off if it backfires, used to happen all the time in my mates gas powered VN.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 07:34 PM   #11
syktlr
stktlr
syktlr's Avatar
i have the same setup,v8 on strait gas it runs perfect and never backfires
eb v8, dedicated gas,twin pipes,ghia interia,au console,el mirrors,drilled and slotted rotors,lowered with superlows and koni 3 ways ...:evil_laug
and maybe selling :
syktlr is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2006, 09:12 PM   #12
eb2flyz
bettering 13.7
eb2flyz's Avatar
perfect example, it all comes down to if the gas system has been setup correctly. if you are having backfires i would be getting your car checked out as there must be a problem somewhere
std stroke, alloy heads, comp cam, tfs manifold, 75mm t/b, 70mm maf, 30lb inj, adj fuel press reg, twEECer
FPV/Tickford Club of W.A
Performance is Electronic
BPT Motorsport
eb2flyz is offline   Reply With Quote Multi-Quote with this Post
