Old 28-11-2006, 09:58 PM   #1
Pistol
pistol
Default top loader or not
what 4 speed man did xe xd esp 351 come from factory I thought xb was the last factory top loader
Pistol is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2006, 10:00 PM   #2
GXL078
GXL078's Avatar
Late XBs on had Borg Warner single rail 4 speed gearbox.
GXL078 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2006, 10:07 PM   #3
Falchoon
Falchoon's Avatar
The Single Rail gear shifter screws into the gearbox directly (and the thread is prone to failing and the shifter ripping out of the gearbox during harsh shifts) whilst the Toploader shifter is bolted on the side of the box and is controlled by linkages. And I think reverse is in a different place between the two boxes - could be wrong, been years since I've had anything to do with either.
Falchoon is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2006, 11:26 PM   #4
ebxr8240
Performance moderator
ebxr8240's Avatar
It was a single rail as std in 351 XD's....
No 9" diff either as std...
Daily driver GTE FG..
Old 29-11-2006, 08:55 AM   #5
Neeek
65 Galaxie Hardtop
Neeek's Avatar
Correct - single rails have reverse in top left, toploaders are bottom left.
And as others have said, toploaders stopped mid-way through the XB range and were replaced by single rails, and 9" diffs stopped mid-way through the XC range (and then only fitted to 351s) and then replaced with BW diffs.
Red on red 65 Galaxie 390FE C6 9"
Neeek is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2006, 09:11 AM   #6
OLDFORDNUT
OLDFORDNUT's Avatar
yep correct,my XB GS UTE with all factory options had a 351,single rail and 9"diff.it recieved regular abuse and the single rail held up quite well,so they are fairly strong box's behind mild 351.
Hervey Bay QLD
Great trades recently- GILMORE
BOSSYONBIKE
OLDFORDNUT is offline   Reply With Quote Multi-Quote with this Post
