Old 07-12-2006, 07:18 PM   #1
CATFORD
SCALDED CAT
CATFORD's Avatar
Default ADJUSTING CLUTCH IN AU 5Ltr ( T5 )
At the moment my clutch pedal sits about 2 inches above my brake pedal and only take up in the last 2 cm or maye even less.....also it doesn't slip at all.....is there an adjustment in the car to fix the pedal hieght or does it have to be done at the gearbox????
I am guessing that it need may need a new clutch!!!
Hope you guys or gals can help....cheers Rory!
"THE CAT IS BACK"
CATFORD is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 08:31 PM   #2
philstoj
philstoj's Avatar
Adjust it at the firewall, theres an adjusting nut there.
It should sit just above the brake pedal, usually when it starts to get higher, you should adjust it again.
they are a pain, mine gets adjusted frequently, maybe its the clutch you have?
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 10:14 PM   #3
superroo
You can't stop the signal
superroo's Avatar
By memory they're meant to have a 145mm of travel, and thats what the bolt changes. However i could be wrong on the travel measurement.
Old 07-12-2006, 11:02 PM   #4
howesy
howesy's Avatar
Pull on the clutch cable where it comes through the fire wall to give some slack and back the nut away from the fire wall 2 turns and start from there. that will bring your take off point closer to the floor. Put it in gear and feel where the friction point is and go further out or back in a bit to suit your feel.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2006, 07:55 AM   #5
Sledgehammer
Sledgehammer's Avatar
If its not corrected by the above adjustment, these have trouble with pedal boxes from time to time and bent clutch pedals.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2006, 04:37 PM   #6
CATFORD
SCALDED CAT
CATFORD's Avatar
Cheers guys thanks for the great info....I will give it ago this arvo!!!
Thanks Again!
"THE CAT IS BACK"
Old 08-12-2006, 07:50 PM   #7
GK
Walking with God
GK's Avatar
Thanks Again!
How did you go with the adjustment?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 08-12-2006, 08:37 PM   #8
lotus
Also check that the pedal return spring has not broken. This will make the pedal come out further than it usually does.
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2006, 11:24 AM   #9
CATFORD
SCALDED CAT
CATFORD's Avatar
Had a few to many beers yesterday arvo.....just about to go and give it a go now.....fingers crossed!!!
"THE CAT IS BACK"
Old 10-12-2006, 05:39 PM   #10
howesy
howesy's Avatar
So did it work out?
Is it adjusted or stuffed
