Old 15-01-2007, 04:50 PM   #1
MAD XE
Size DOES matter!!!!
Default Alloy Heads, Which type is best???
Not sure If Ive put this in the right place, but I'm sure I will find out...
I'm building a 408 Clevo stroker to go into an XE ute, but going to run straight gas (Gas Research) as I plan for it to be a daily driver and dont want emission problems from the EPA again.The bottom end is almost complete and the next step is the heads. Does anyone know of the ideal head for Gas and this cube combo,AFD, CHI, Kostecki??? 2v, 3v, 4v...even factory cast...., or do you know of where I could get a comparison of head performance....Thanx
MAD XE is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 04:59 PM   #2
TZENU
XY Driv3r
TZENU's Avatar
http://www.fordforums.com.au/forumdisplay.php?f=9
check this side of the forums and Welcome!
i wouldnt suggest starting a thread on which head is better neither...
Genuine Faker NOW BROKEN
Imagniation is a human element creativity is the result
TZENU is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 05:00 PM   #3
xwgasaxe
under new management
xwgasaxe's Avatar
Send me a message when you have bought your GRA throttle bodies as I have made some annular discharge venturis which will increase your CFM flow as the GRA flow figures are a long way below what they are quoting.
XW tarmac rally car, 3/4 race cam, NGK spark plugs
xwgasaxe is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 05:05 PM   #4
MAD XE
Will do..Already got them..
Old 15-01-2007, 05:19 PM   #5
xwgasaxe
xwgasaxe's Avatar
What models have you bought S400 / S440? Those are the quoted flow figures but the 440 will only flow around around 298 to 308cfm at 1.5'. I have made up various different venturis that will lift the flow between 385 and 422 if your feeding a stroker.
