Old 14-01-2007, 07:24 PM   #1
5L
[ 5L ]
5L's Avatar
Default carbon canister ticking
my au xr8 has a ticking carbon canister and it is starting to annoy me. what is the best way to fix this,
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 07:25 PM   #2
JefXR8
JefXR8's Avatar
is that under the l/h front guard?
Cause mine does the same if it is :/
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 07:30 PM   #3
5L
[ 5L ]
5L's Avatar
yep it is. i have been told it is a common problem.
Old 14-01-2007, 07:40 PM   #4
TwistedEL
TwistedEL's Avatar
I think you can put some foam around it so it doesn't knock
Also I've heard that if you get an edit you can change the RPM at which the ECU will cycle the cannister.
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 08:08 PM   #5
RG
Back to Le Frenchy
RG's Avatar
Turn up the radio, cheapest way. I've got the tick. Heard on here before that it's the "Tickford tick".
Seriously though I got sick of my tick too but after a while I just got over it, there are much better things to spend money on anyhow.
Old 14-01-2007, 08:51 PM   #6
FRDTUF
FORD TOUGH
FRDTUF's Avatar
Yeah, i'm the same... really used to annoy me, after a year or so i got over it...
FRDTUF is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 09:15 PM   #7
TwistedEL
TwistedEL's Avatar
Geez I might put my cannister up on Ebay as a genuine Tickford item in that case
Old 15-01-2007, 01:07 AM   #8
5L
[ 5L ]
5L's Avatar
ok cheers guys, i suppose when people ask me what that noise is, i can now say its the tickford tick. like its something special.
:lookedat:
Old 15-01-2007, 07:20 AM   #9
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
If you would like to get rid of the noise all u have to do is cable tie a car wash sponge in between the canister & inner guard. Hope that helps.
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 07:34 AM   #10
OzJavelin
OzJavelin's Avatar
I thought it was the purge valve for the fuel system? It also affects non-Tickford V8s (like mine) :(
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 03:43 PM   #11
lethal_xr8
lethal_xr8's Avatar
i had the same annoying noise in my xr8, i went to the local carpet shop and got some scrap underlay and cable tied it around the little box inside the wheel arch and now you can't hear a thing. Was gonna replace it but was told a new one would start doing it any way.
lethal_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 04:08 PM   #12
atec77
Wrap it with some gortex and silastic .
Old 16-01-2007, 09:09 PM   #13
AUTickford
XD197
AUTickford's Avatar
I went to see my mechanic mate at ford and he said it was the purge solenoid and to wrap it up to quieten it down, common as he said. So make sure you wrap up the solenoid,s and the plastic lines as well because i just wrapped the cannister and it still made the noise. Maybe that was just with my car,Who knows?Reminds me of galloping horses, if only there were a few more horses under the bonnet
AUTickford is offline   Reply With Quote Multi-Quote with this Post
