16-01-2007, 10:58 PM | #1 | ||
FTF Club Moderator
When changing diff gears your speedo will be out, so how does one get around this problem. I thought the edit would be able to do it, but have heard it cant.
If I goto 3.7 gears how much will my speedo be out? This will stuff up the auto shift points as well, wouldn't it? So to the people that have changed diff gears. How did you fix this delima? (sp?)
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
17-01-2007, 01:14 AM | #2 | ||
Boost Addict
i used to have 3.7s in teh rear, inc ombination with the 17/255 is was running the speeda was only 5% out which wasnt too bad.
but it was the ideal ratio choice between taking off and quater mile shifting were perfect
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
17-01-2007, 09:32 AM | #3 | ||
Smile
The edit will fix the shiftpoints.I changed speedo cog in the gearbox to correct the problem somewhat.Ultmately a good electronic speedo corrector should do the job.There are people who can do it for a fee
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
17-01-2007, 10:59 AM | #4 | ||
Back on the road
Speedo corrector between the vehicle speed sensor, and the Dash. Then either the edit (to change value for diff ratio), OR another speedo corrector between the dash and the ECU to reverse the correction you made for the speedo/dash...
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
17-01-2007, 02:52 PM | #5 | ||
If you get a speedo corrector and intercept the wire as it comes away from the box then the value has changed before it goes anywhere. First you need to get a gps and work out how many K's you are out and percentage it. Mine worked out to be around 11% out after changing the diff and correcting the factory. Mine was way out now at 100kph i am doing 99 which is where i want it. I went from 3.45 to 3.08 but the principle is the same you are just going the other way. And if your not really patient and double and triple check the orientation of each piece on the board then dont build your own kit. There is one from states that does the job, bit more expensive but you can have dual settings so when you change diffs you flick a switch back to original or other setting.
http://www.superlift.com/accessories/truspeed.asp Just one available |
17-01-2007, 09:25 PM | #6 | ||
i have a 3.73 LSD and 235/45/17 tyres and my speedo is out by 6km/s at 100km/h. This was corrected from an insane 22km/h difference by a number 19 speedo gear in the transmition. I dont know if a bigger gear exists to get it closer.
17-01-2007, 09:32 PM | #7 | |||
17-01-2007, 09:48 PM | #8 | ||
[QUOTE=Casper]is that the black gear?[/QUOTE
I honestly cannot remember what colour it is. All I know is its a number 19 as it was the largest one my mechanic had at the time. But thinking about it, for some reason red sounds more familiar, but I am still not quite sure. Sorry about that Casper. |
17-01-2007, 10:48 PM | #9 | |||
Highway Taxi
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
17-01-2007, 10:51 PM | #10 | ||
Black is for a 3.45 as far as I can recall.
