#1 | |||
A humorous statement
G'day everyone. What's the clearance of a TS50 front bar on XR suspension?
Black manual AU1 S. S Quote:
if its anyhing like my xr50 front bar its none lol
#3 | |||
I hope it'll fit up my driveway. I'm going to have to find out the clearance in mm so I can test it.
335 kw of goodness
T3 & AU XR are the same hight..
CAUTION! STILL Contain's opinion's & fact's that may offend !!! ![]() 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
well at the moment my ride height from centre of my wheels to the lip of my guard is 335 mm and i cant get out my driveway :/ im trying to get some springs to take it up to 350mm but still it will scrape a tad
#6 | ||||
#7 | ||||
DJR TM#54
Location: on my p.c now with internet! ok i'll still use works internet too.
I have the XR50 front on mine, i still stock height. I do find the front does scrape more than the old XR front bar, but i just go very slow when going over speed bumps or entering & exiting drive way. It's only the bottom & no way can see it unless the get down on the ground & look under the car.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains ![]() |
#9 | ||||
Its not only the height or ground clearance that is the issue with these bars. The main clearance problem, or more precisely the lack of it, is the length of the overhang in front of the wheels. And also because the bottom of the bar is square to the nose i.e. no taper
Ford Oz had to get special permission from Ford US to allow this bar because it is outside the usual minimum parameters for approach angles. No doubt it was only allowed due to the limited build numbers of the T Series I had to put some more concrete at the bottom of my driveway to lessen the angle off the road
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
