Old 11-03-2005, 06:36 PM   #1
blue
Thumbs down head gasket gone
Hi guys
My first post here:
I have just bought my first car a 1991 EA-S wagon with 208,000 on the clock, before i bought it i got a RACV check which stated:
1) excessive freeplay on the drivers side steering rack.
2) oil leak from the timing cover area.
3) temperature gauge was reading too low.
4) Radiator cap seal damaged
Has anyone got any advise how much this should cost to fix up and if it would be possible to do any of the work my self?
I have just done my first oil and filter change using the instructions off this site, so am no expert but happy to give it a go myself if the fixes are fairly simple.
any help would be greatly apreciated
many thanks in advance
Andy
Old 11-03-2005, 06:47 PM   #2
LUXO_8
windsor user
the rack is probably buggered, you can get reconditioned units, or take your chances with a seccond handy from a wreckers.
change the thermostat, coolant, and cap - chances are they all havent been changed in a while
get yourself the max ellery service manual, its invaluable for doing home repairs, only around 40 bucks...... i got mine from repco, but im sure you can get it at most places.... except autobarn i noticed!
Old 11-03-2005, 06:56 PM   #3
cArSiK
For a 91 EA with those FEW problems , it sounds like it must have been a well looked after car...
James
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2005, 11:50 AM   #4
FRDXR6
FRDXR6's Avatar
^^^ Thats what i was thinking, the RACV checks usually pick up most things and if its thats all thats wrong with it for a car thats 14yr old its a good buy!
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2005, 04:04 PM   #5
Barry_v
rocknrolla
Barry_v's Avatar
degrease the front of the engine and monitor the oil leak. it might not be that bad, just nobody has cleaned the engine in a while. I'd advise you to spend the money on any cooling system issues, you dont want to be doing a head gasket. if at all suspect, replace the radiator with a new one. they can be had for under $200 new. the thermostat is a couple of bolts and hose clamps, you can easily do that yourself.
Barry_v is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2005, 09:00 PM   #6
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
just don't re-tighten the top housing bolts too tight... learnt that one the hard way...
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2005, 05:26 PM   #7
blue
O.K
Thanks guys,
I got a Max Ellery manual and a can of degreaser from Repco on sunday and will get the replacement thermostat this saturday. will a torque wrench stop me over tightening the top housing bolts?
How much should a new steering rack cost?
the things I listed are just those that need to be done immediately and that i have enough money left over from buying the beast.
the report also stated:
all belts were aging /perishing (well 14 years old what do you expect?)
Clutch has freeplay and clutch slip induced,
shock absorbers rear noisy,
suspension bushes aged/perished
and finally battery terminals corroded.
so it will still need some work done on it before we attempt the Nullabor.
Old 15-03-2005, 06:00 PM   #8
LUXO_8
windsor user
it still sounds like one fo the better Ea's out there with all of the things you mentioned! haha
seriously though, if ya do a few of those things each week you'll get them all done in no time...
once they are done, it will be a good car, that should be trouble free...
Old 16-03-2005, 07:55 PM   #9
SileNceR
SileNceR's Avatar
I should get one of these checks so I can make a list of things to fix....
they'd probably have to go into overtime just writing it out... lol
211RWKW EA
Old 11-04-2005, 02:57 PM   #10
blue
well the great buy seems not so great now i need a new head gasket.
it seems the problems i have been having starting the last 2 weeks were because the cylinders were filling up with water, i had to re fill the coolant 3 times from friday to today (monday) as the warning light was lighting up.
took it into the mechanic today and there was a load of white scum top of the oil and oil filler cap, ties in with the white smoke i saw lastnight coming out my exhast in the rear view mirror.
the thing is the temperature gauge hasnt ever got past the 'r' of the NORMAL, so was it just old age being a 91 ea -s pack with 210000 on the clock. should the racv test have picked the head gasket being on the way out or can it just go without warning?
so far i have worked out that i should ask for a steel au gasket any other advice. i dont think i am up to a whole engine strip down just yet as i have only just managed changing the oil/oil filter, coolant and thermostat so far.
would the oil leak from the timing cover have any thing to do with the head gasket going?
thanks for any advice
andy
Old 11-04-2005, 05:06 PM   #11
ilsautomotive
Former E-Series Member
Ah the joys... the failure to heat up is a result of the thermostat being stuck open. It will also cause crap fuel consumption and do other damage over time. Remember that the genuine Ford item is barely over $20 and the only one known to do the job properly. It seems the seller must have known the gasket was about to go and ideally the RACV should have picked it up, there is usually a degree of warning.
The most important thing is ensuring the head is shaved so it is perfectly square. The failure to do this from the factory is one of the main reasons why they blow at all. The AU gasket is a good idea, as well as checking over the radiator etc. Keep us posted.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2005, 08:32 PM   #12
SileNceR
SileNceR's Avatar
i got a thermostat for ford and it constantly fluctuated to the point it actually killed my headgasket...
funnily enough the next one i got, also from ford, which i got with my new headgasket, has been awesome...
211RWKW EA
