30-01-2007, 07:10 PM | #1 | ||
i got a 5 speed CFI EA and when i floor it from takeoff it's all jerky and bunnyhops, but it will take off smoothly if i gradually accelertate, and also when it's going smoothly if i floor it it' has a real flat spot, this happens in 1st,2nd and 3rd, and i have got the timing right. so does anyone know what could be causing this.
30-01-2007, 07:43 PM | #2 | ||
Hmmmmm
could be bad fuel, clogged injectors, first off try replacing your fuel filter, if thats no good then u could try chaning the spark plugs and leads also.
31-01-2007, 04:27 AM | #3 | ||
Could need an ignition tune up, my EL had a problem like that for a while.
Like Juzxr8, spark plugs could be next. |
31-01-2007, 07:33 AM | #4 | ||
any money its blocked injector(s). id try some injector cleaner first.. i had the same issue on my ea spac. i got quoted $700 for a clean... :( but its really a process of elimation.. or 2nd hand injectors
but yeah definately try the injector cleaner |
31-01-2007, 12:42 PM | #5 | ||
I have a problem like that but I think mine is a drive line problem.
Now driving an unbreakable Hilux, which is becoming full of rust : |
