Old 16-02-2007, 02:03 PM   #1
ianw100
Default AU3 Auto Selection problem
We have had our AU3 I6 wagon for ten months now and it has been fine. Fitted with gas conversion last October, very happy with it. Over the last several months when first started in the day it usually will not select any gears, moving the selector to each position it just stays in neutral. After about 30 seconds it comes good, and is fine for the rest of the day. It has done 140k and the auto was serviced about 12k ago. Would appreciate any suggestions as to what might be wrong/how to fix it.
ianw100 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 02:16 PM   #2
The Monty
Just slidin'
The Monty's Avatar
Mine does it sometimes. I just keep moving it till it clicks in. I have heard that if you are parking on a hill, and have low tranny fluid, it can all go to the back of the auto, and it wont select a gear.
Also, it takes about thirty second after you start your car for the fluid to gain pressure, so you should try not to drive until then anyway.
Hope that helps.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 16-02-2007, 05:50 PM   #3
alpineau
alpineau's Avatar
I had a similar problem to what you’re having now except I could not select 1, 2, 3, manually, the car drove fine in d and went into park and neutral but not the other gears. I took it to an auto shop and it turned out for be the gear selection switch on the outside of the gear box. Basically this switch tells the gear box what position the gear leaver is in (I think that is close to what he told me)
I was also told it happens because it sits out side the gear box and it's not water proof and it seizes causing it to stop selecting gears
Hope that helps
AlpineAU
OLD - 2000 AUII FUTURA 75TH ANNIVERSARY GOLD 4 SPEED AUTO
OLD - 2006 BF MK2 XR6 BIONIC 4 SPEED AUTO[
OLD - 2007 BF MK2 XR6T SILHOUETTE 6 SPEED MANUAL
CURRENT - 2009 FG G6E BLUE 6 SPEED AUTO
alpineau is offline   Reply With Quote Multi-Quote with this Post
