mezzo forte
Hi guys n gals
When I do a cold start, I get a clickety-clickety kinda noise coming from the motor. After about 30-60 seconds it fades away. When still cold, and I rev the motor, the noise disappears and then occurs again when the revs reach idle level, but only for a couple of seconds usually. I was guessing maybe an idle bearing as the noise ceases when revved? Or if not that, the time before enough oil reaches the top of the motor? Although the other day I walked past an el as it started up, and I think I heard the same noise. Is it common? Or serious? Thanks in advance |
Spin 'em Habib !
if you heard it in an EL , it must be Serious
AU2PWR |
Formally FairmontPom
My VCT Ghia does the same when cold, usually only for as long as it takes to back out of the driveway, then it goes.
I have no idea what it is, probably something connected to the serpentine belt, ie, tensioner or alternator or one of the powersteering/water/aircon components. Thats a fat lot of help to you isn't it? !!! |
Might be lifters ... then again it could be a number of things though.
XD197
Wtf is an idle bearing, could it be related to a lumpy idler gear hahaha
![]() Last edited by AUTickford; 16-02-2007 at 06:51 PM. Reason: forgot a bit |
it could still be lifters, it could also that the w rating of the oil is too thick, try putting engine oil flush through it next time you change the oil, then put some lifter free and tune up in with the new oil and see how it goes
Tappets maybe?
Sounds like the old AU 6 rattle to me... ur not the only one with it mate.
Kinetic FGX XR8 ![]() Old Rides: BF MkII 07 XR6 , Seduce in colour.... ![]() AUII TE-FORTE Monsoon Blue,Full Cobra Performance exhaust system, G+D CAI, Crow Cam, Tickford Suspension, TE50 Kit, RDA Slotteds, Ridin on Advanti 18's
Spin 'em Habib !
the Rattle that shows the I6 is Still Alive and ready for More Abuse , 95% sure its going to be Low Oil Pressure
AU2PWR |
mezzo forte
Thanks guys. I might ask my mech what grade oil was used on the last change.
ur probly best using a 0w-40 or something like that, thats what im using. rattle is now only at startup
Hehe, I noticed the same on mine when I bought it. I even took it back to dealer and they said it sounded normal, Its a very quiet rattle on mine that clack clacks when you rev and then dissipates. I figure its normal, I've had the car almost 3 years now and the sound is still there and no worse than when I bought it.
