19-04-2005, 02:57 PM | #1 | ||
Hmmmmm
as im replacing the head gasket in my ea i was considering using an AU steel gasket and figured while i was at it y not put on an EF head.....does this just mount straight on where the old head did....or would i have to do some modifications? also what sort of price am i looking at for picking one up....and where?
19-04-2005, 02:58 PM | #2 | ||
I have a EF tickford head you can have for $400 if you want, they straight on as far as I know, I was going to fit it to my EB. You will need to fit your own valve springs though.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
19-04-2005, 03:09 PM | #3 | ||
PM me if you want
Yes straight bolt on, everything fits\lines up no worries.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
19-04-2005, 03:52 PM | #4 | |||
what happens to the compression ratio?
19-04-2005, 06:25 PM | #5 | ||
Probably go up a little bit. I believe.
19-04-2005, 10:03 PM | #6 | |||
I have heard it lowers compression unless you have EB-> pistons.
19-04-2005, 10:06 PM | #7 | ||
Mmmm... Bikini Carwash...
It would lower the comp ratio as the ef heads dont have the bump in the chambers as the ea chambers do, just get the head shaved and chambers cc'd to EA specs, taking into consideration the thinner head gasket if u decide to use the AU one, that is if it really worries u
'87 XF UTE 351C '91 Peugeot 405 Mi16 '89 EA Falcon GL Last edited by GTFalcon 351; 19-04-2005 at 10:13 PM. |
19-04-2005, 10:18 PM | #8 | ||
Low and Loud
Yep you sure can Gremlin, as ive got one on my car now!
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
20-04-2005, 05:44 PM | #9 | ||
So 3.9 pistons are dished and EB/ED 4.0 are flat top?
20-04-2005, 09:46 PM | #10 | |||
I think EB onwards are just less dished. I was told the pistons were changed because the bump was removed. Considering the size of the bump I would have thought it would drop the CR a fair bit. I remember a while back hearing that an EF head on an EA block would give a good CR for turbo's.
20-04-2005, 11:58 PM | #11 | ||
Two > One
That is exactly correct.
EA pistons = 13cc dish 4.0L pistons = 11cc dish (could be 9cc) EF head on EA pistons would result in arround 8.6:1 comp i would say. Have the EF head milled down to achieve arround 9.0:1 comp and you will be in business.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
21-04-2005, 10:35 AM | #12 | ||
With the AU gasket, it would bring the comp back to normal as they are 20thou less than th E-series ones.
21-04-2005, 10:42 AM | #13 | ||
Low and Loud
CRAP! i knew there was a reason why I was suppose to use a AU Headgasket instead of a Graphite one :(
Would a lower comp make it slower at all? or use more fuel?
21-04-2005, 11:19 AM | #14 | ||
Last warning
with stock timing it woulnd't be the best.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
21-04-2005, 12:27 PM | #15 | ||
Hmmmmm
when i put it all on....would i have to get the ecu retuned? or will it all be sweet?
21-04-2005, 12:39 PM | #16 | ||
PM me if you want
Will all be fine, the computer will be handle the slight change in cam specs without a problem.
