Old 15-03-2007, 02:05 AM   #1
gambino
bumps in the trunk
Default fuel gauge probs?
Hi everyone,
another problem has arose, i fitted a sports cluster(ed i think)from the wreckers to replace my standard one, a part from the oil pressure gauge (need the sender thingy for it) not working, my fuel gauge isn't working.
I fitted it on the other day and took it for a test to see if it was all good, everything worked except the odometer and oil pressure gauge, i went to get some fuel because i was low, i filled it up and came home. The past few days ive been driving around, the needle goes a little over full, and comes back about 2 mm's and stays there, i know ive driven enough to get it to about half a tank.
So basicaly, it worked when i fitted it and stopped when i filled her up
any ideas?
thx
1994 NC Fairlane Ghia V8
1995 Ef Gli
gambino is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 05:59 PM   #2
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
in tank fuel sender may have sh!t its self as mine has. can happen out of the blue with no warning apparently. can only buy it genuine from ford. accessable from where u get to your fuel pump as it is mounted on the same unit. be aware this is only and idea and ur problem may be different.
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
