Old 20-03-2007, 02:02 PM   #1
burkie_21
wild xr8
burkie_21's Avatar
Default Ford SVO X-303 or Z-303. any other brand do similar cams???
Ford SVO X-303 or Z-303. any other brand do similar cams??? they are about 450 each, they are the recomended cam for my application, have also been priced on a au v8 brute cam, think its crane, they are about 500. any help is appreciated
cheers
burkie_21 is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2007, 02:06 PM   #2
Allen
You win again, gravity!!!
Allen's Avatar
Proberly better off asking in the windsor forum...
I've searched for the Ford motorsport and SVO cam specs before, but can never find the exact specs...
So far I've been doing lots of testing on the dyno2000 program, and have found the Crane 2030 to suit my needs best... Many cam manufacturers dont like to give out there specs, which makes it hard to choose...
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2007, 02:25 PM   #3
burkie_21
wild xr8
burkie_21's Avatar
yeah i've been lookin at that to. thats the 1 that the au v8 brutes used
Old 20-03-2007, 02:31 PM   #4
Allen
Allen's Avatar
This is an old dyno simulation... but it should give you an idea to the torque characteristics of the 2030...
Since then, i've changed a few more things around and got it to 350hp, with a very strong torque curve... I think when I first entered these figures, I stuffed up valve sizes and cam lift... but you get the idea.
Old 20-03-2007, 02:31 PM   #5
Walkinshaw
Two > One
Walkinshaw's Avatar
2030 with 1.6 rockers with an AU long engine (auto, and exhausr) should put down an easy 165-170rwkw.
Old 21-03-2007, 05:05 PM   #6
AUTickford
XD197
AUTickford's Avatar
Do any of these cams give you a working rev range like on the crow cams site. if i couldnt find that out i wouldnt buy it, thats one of the most important things in selection of a cam.
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2007, 05:21 PM   #7
frd_crzer
:D:D
frd_crzer's Avatar
the best person to ask is gthofan he works for wade cams and he should have an idea about the cam specs
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2007, 05:34 PM   #8
Steady ED
Steady ED's Avatar
+1
TFS1 if it's manual or you can handle lumpy idle with a slusher.
Steady ED is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2007, 07:03 PM   #9
burkie_21
wild xr8
burkie_21's Avatar
how much is a crane 2030 worth??
Old 21-03-2007, 07:13 PM   #10
burkie_21
wild xr8
burkie_21's Avatar
ifyour wanting toknow wat i got then here it is. wat im peicing together is a edelbrock performer 2 intake manifold, performer heads, 70mm throttle body, au xr8 maf housing, has genie exhaust and will run a strengthened auto with 3.45 diff. will run stock bottom end!! will have a 70-80hp shot of nos setup. cant seem to get info and price on cam to suit. they all want diff ratio 3.7 or higher. i drive a lot on highway which is prob why ill stickto 3.45 diff ratio
