Old 23-03-2007, 11:27 PM   #1
AU2 Pursuit Ute
Fords : outlast Religion
Default AU2 200Kw to 220Kw ???
I have the opportunity to swap parts from my AU3 220Kw XR8 to my 200Kw AU2 Pursuit Ute. I have changed 70mm T/Body, MAF and Intake tube, and Upper Plenum chambers. Went to change rockers and found 200Kw already has Yella Terra R/Rs. ( I hope that they are 1.7-1 on both engines! I do not know how to tell the difference, so I measured from shaft to both ends, same distance). Ute still hasnt got the grunt of the sedan. About to swap ECU computer, is this as easy as it sounds? will it make a difference? Is there any other parts that are Different? Anything else I should swap? Any suggestions would be appreciated. Thanks ........ Dave
AU2 Pursuit Ute is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2007, 12:34 AM   #2
Bundy
All Ford Club Life Member
Bundy's Avatar
Sorry bit beyond me but Free347 I think my be of some help
I also thought that all the AU pursuit utes were 250kw anyway?
Worked AU XR8 Ute - Toy
Std FG XR6T Ute - Daily
Supercharged BA 6 Ute - Wife's daily
351W F150 93 XLT 4x4 Supercab
Bundy is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2007, 12:36 AM   #3
b2tf
not here much anymore
b2tf's Avatar
Only Pursuit250's were 250kw as they shared the 5.6 stroker as found in T3's.
All other utes were 200kW from factory, with the Series I XR8's being 185kW.
2024 F150 XLT
Old 24-03-2007, 01:06 AM   #4
philstoj
philstoj's Avatar
AU2 utes from april/may 2000 to april may 2001 were 185kw, only exception is the AU2 XR8 Pursuit :
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2007, 08:51 AM   #5
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Mine came with a 270kw odd engine, must be a special one. : :
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2007, 10:46 AM   #6
TwistedEL
TwistedEL's Avatar
To answer the question you cannot swap the ECU without having it recoded to suit your BEM
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
