Old 24-04-2005, 03:47 PM   #1
groove_injector
Post EA alarm installation
I have started installing an alarm into an EA falcon. I have run into trouble in wirrig up the indicators to the alarm.
The alarm unit has 2 wires that need t obe connected into the left and right indicators. I have tried to splice them into the hazard lights at the bottom of the loom that connectes the indicators/horn/wippers. The first time I connected it up it, it worked fine and I was a happy man. Then I soldered it all up and things got funky. When I tested it, the the oil and battery light where the ones flashing and the incators did nothing. I checked the indicators to ensure they work correctly and they did. I couldnt figure out what was going wrong
Next I would try and wire it into the wires that connect to the indicator stalk. I traced the wire and cut the connections, but the incdiators still worked!!! I cant figure this out! I am trying to obation a wiring diagram to determine if I can figure this out. Is there any one here that can help me out.
Thanks
groove_injector is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2005, 04:38 PM   #2
XRated
Shoot.
XRated's Avatar
Hahaha is that you Trav?! You've certainly made a mess of the EA :P
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2005, 04:46 PM   #3
XRated
Shoot.
XRated's Avatar
BTW, how do you run the wires for the tweeter through the dash in an EA? (Same one)
20V Turbo
Old 24-04-2005, 06:20 PM   #4
InitialD
Low and Loud
InitialD's Avatar
To make the indicators flash, as I just fitted an immobiliser to my car, you need to wire the Alarm wires to the 1st and 3rd Wires (Green & Green/blue i think) on the stalk connector.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2005, 01:45 AM   #5
sphell
sphell's Avatar
yep indicators are green and green/blue. Just pick up the wires under the steering column where they go into the plug.
sphell is offline   Reply With Quote Multi-Quote with this Post
