Hey Guys,
I have a AU Series 1 Forte, and today I decided to take off the ugly Door protectors that go down the sides of the doors on both sides. Now I have bogged all the holes however the sticky tape/foam the was holding them on for extra support isnt coming off to easy... ive tried using a heat gun, scraping, acetone... nothing seems to work.. Any suggestions?? |
Karasu
Prepsol will take the double sided tape and residue off but you'll need to let it soften up a bit first, if you want to get it off a bit faster paint thinners will do the trick, failing that if you go to an automotive paint supplier you can get an attachment for a drill which has a wheel with rubber strips on it that will rip it off quickly but can also damage the paint surface. Acetone isn't aggresssive enough and evaporates to quickly to do the job.
#3 | |||
Back to Le Frenchy
Wax & grease remover + elbow grease always does the trick for me when it comes to the tape and residue.
Blue to the bone!
Throw up some before and after pics when your done please?
ecalyptus oil works wonders actually, then clean that otherwise nothing else will stick to the surface.
yeah i want to see some pics before and after please
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
