Spr Jenkins
Does anybody know anything about these cams? What the specs are etc Was looking at getting one second hand but know almost nothing about them. Cheers Joel
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands" -Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times -Chuck Norris doesn't sleep. He waits. -Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain. |
Spr Jenkins
I did some searching and found a little info but no specs or power figures
Adapt or perish...
Are you absolutely sure they're suited for the rocker ratio of the AU?
I think you'll find they're mostly for E Series vehicles... but don't quote me on that.
Carless
Spr Jenkins
good question, i'll have to check
RPD didn't make cams for the AU ... only E-series.
And as I found out ... there are differences between the A and E-series cams .... and it's not just rocker ratio.
Spr Jenkins
thanks mate
What Wheelspin?
apart from rocker ratio, whats the difference? i have seen e-series cams work in au's........
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
How ... I tried putting one in ... and the lobes are different widths (about 1mm out) .... the rocker arms snap when trying to torque them down ... hee hee
TL40 Wagon?
AU Cams with AU rocker will work in an E series head and E series cams with e series rocker gear wil work in AU heads. Match the cam and full rocker assembly and you will be fine. valve clearance need to be checked again and shims removed or installed in the lifters if it's not right of course.
that will be a esseries cam, Jaysen told they didnt do em when i inquired for one
